IIS and a preliminary report
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 19, 2013.
  1. bwilson4web
    16,281
    Over the years, the IIHS has demonstrated a pattern of releasing results that often disparage Toyota products. For example, their increased roof crush press release went to pains to point out Toyota had just lost their top rating . . . with the new test. In effect, IIHS 'moved the goal posts' and then made sure Toyota lost their recently awarded top rating. Similar results came from their most recent partial-offset test. Now it looks like they are at it again.
    Read more: http://www.autonews.com/article/20130819/OEM11/308199942/breakthrough-or-bauble?-safety-lab-is-on-the-case#ixzz2cOnH13qL
    Now I have no problem with testing accident avoidance systems and certainly one that fails to stop the car is important. Then I looked at their mock-up, rear-end car:
    Radar reflectivity is a function of having angular metals. I understand the IIHS may want accident avoidance equipped cars to avoid a repair bill from testing by using a foam mock-up. However, a foam block covered with the pretty plastic wrap shown in the photo is not going to have a similar, radar reflective cross-section. The toyota system uses a millimeter radar sensor and camera. This type of 'press release' is typical of IIHS with their anti-Toyota tone.
    If the press release had technical information about their mock-up, it would make sense. So sort of verification and validation test that compared the optical, radar, and even audio characteristics compared to the rear ends of their test vehicles. But I can't tell if they are using the engineering equivalent of cardboard boxes or a weather balloon . . . without the reflectors.
  2. hill
    8,858
    If you ask IIS to set up a test with more angularity - you KNOW they'll make sure the Toyota can't use its radar. Next, they'll set up the test with one of these.
    minkus and bwilson4web like this.
  3. Michael King
    Michael King Member
    72
    33
    Raynham, Massachusetts
    2018 Prius Prime
    True.
    But a flat box must have some kind of radar signature. I'd be interested to see Toyota's response.
  4. bwilson4web
    16,281
    Well now I understand why the IIHS is being such sh*ts about it:
    The NHTSA conducts vehicle safety tests and awarded the "Prius v" five stars:
    Shoppers/5-Star+Safety+Ratings/2011-Newer+Vehicles/Vehicle-Detail?vehicleId=8142
    Apparently this is enough to cause the IIHS to react badly.
  5. austingreen
    austingreen Senior Member
    13,688
    4,222
    Austin, TX, USA
    First its the IIHS, not IIS. IIS is a microsoft product. I don't think IIHS has anti-toyota bias, but they have shown a pro-tank built type vehicle (SUV) bias. They enjoy making vehicles heavier and more expensive. The prius v, if it were a very safe car, would get rid of all those pro-SUV arguments, and reason they have fought cafe standards. As we get further from the slower speed limits, bigger heavier cars are needed to make us safe, the IIHS loses power.
    lensovet likes this.
  6. ETC(SS)
    7,264
    I'd have to know a little bit more about the target (and [sic] Pre-Collision) system before I accused the IIHS of malfeasance or of "Prius Hate."
    OK...so the target probably wasn't aluminized mylar-wrapped foam. Even if it was radar-transparent, that slab-sided aluminum carrier sure as heck isn't. :)
    I'm thinking that the Prius should have sniffed that out and started a backing bell before it plowed through the target.
  7. austingreen
    13,688
    4,222
    Austin, TX, USA
    I agree this is not prius hate, but.... IIHS has to keep showing safe cars are unsafe. The primary safety device in a car, always was and always will be the drivers brain. As cars become safer drivers become more complacent. Its best to get drivers not to drive distracted (drunk, texting, eating), than expect these drivers to be protected by the IIS. But, if we have the technology, and it appears like it is developing, why not make these distracted drivers safer. Not having it work perfectly on a target does not make the prius v unsafe, it simply means the driver must continue to be that safety system. If IIHS was saying, the stystem is a rip off, that it doesn't work that well, that would be one thing, but a driver is hardly less safe with it than in a car without it, unless she/he is realying on it instead of their brains.
    jonb505 and Zythryn like this.
  8. bwilson4web
    16,281
    I don't think the car in the photo is a Prius v based upon the wheel covers and front grill. Of course the narrative in the press release does not have to accurately describe the photo . . . which may also be photo shopped.
    Assuming that 'cart' is aluminum, it should have shown up to a radar but the photo looks like someone might have edited it. Otherwise that building behind it has suffered some strange relativistic effects. <grins>
  9. tawp
    tawp Junior Member
    I have a 2010 Prius 5 with the Advanced Tech Package that has the PCS similar to if not the exact same as this vehicle. If I recall correctly, the manual states that the PCS will only stop the vehicle if it determines a crash is unavoidable with a MOVING object. I believe that by design, it won't prevent an impact with a STATIONARY object.
    ... I can't seem to find it in the online version of the manual, so I might be wrong about this. It does say "The sensor cannot detect plastic obstacles such as pylons"
    ... under the section for dynamic radar cruise control, pg. 229 in the manual says the sensor may not correctly detect "Vehicles that are not moving." I always interpreted that in ANYTHING using the sensor (PCS included) may not detect/react to stationary objects/vehicles.
    bwilson4web likes this.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm not feeling paranoid today, so I'll give the IIHS and CR the benefit of the doubt and just suggest that Toyota gets singled out as a compliment, as one of the leaders of pack in safety.
    I acknowledge that Toyota may not see it that way, and reasonable behaviour by the IIHS would have been to forward the results and test protocol to Toyota for comment before they publish. That way any peculiarity of the testing system that failed the car in the test, but would not be seen in actual use could have been sorted out.
  11. 3PriusMike
    3,100
    2,419
    Silicon Valley
    It has to be a Photoshopped image. Why else would the rear wheels be blurred (moving forward) while the front wheels are already stopped (not blurred)? The front headlights are stopped and the tail lights are blurred and still moving forward.
    Mike
  12. austingreen
    13,688
    4,222
    Austin, TX, USA
    Looks like too long of a shutter speed on a vehicle that was moving then stopped. Don't know the vehicle though.
  13. Trollbait
    12,605
    The system activates based on speed differentials with up coming objects. So it should work for a stopped car. Other wise the system would be of no help in stop and go traffic.
    http://www.toyota.com/t3Portal/document/om/OM47840U/pdf/sec_02-04.pdf
    The pre-collision system is on page 256.
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    This happens when you're panning to try to capture motion (with a slower shutter speed, rather than trying to "freeze" the car in the image). I think its referred to as the parallax effect.
    Here's an example:
    Trucks OTR. - Canon Digital Photography Forums
  15. austingreen
    13,688
    4,222
    Austin, TX, USA
    Right absolutely, but don't see the pan, because the blow up obstacle is stable. It makes it look like the car stopped and did not hit the battle bot. I would like the article would not want the given photographic effect.
  16. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    I thought the reason why IIHS was better than government testing was because they had the money to simulate 'realistic' crashes. What next, a cardboard pedestrian?
  17. ETC(SS)
    7,264
    Would you volunteer to be a 'real' pedestrian? :eek:
  18. bwilson4web
    16,281
    Based upon the headlight, grill, bumper mounted foglight, and body shape, I'm fairly sure this is some variation of a Chevy Orlando. The seven spoke wheels do not match the five spokes seen in Orlando sales photos but that could be an option.
  19. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    It is.
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    If so then wouldn't the camera see the foam mockup? I suspect it relies on radar only - no camera, but that's just a speculation.
