Combo Problem: Yellow Brake Indicator Light, Noises
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EazyMack, Aug 7, 2013.
  1. EazyMack
    EazyMack Intelligently Designed
    Southern Cal
    Hey folks. I did a forum search but was unable to dig up anything with a combo problem like the one I am having.
    I have a 2004 Prius. The yellow brake warning indicator light is on. I also notice that there is a noise coming from under the hood near the dash whenever: a) I open the driver's side door; b) the car is on or running, including while driving; c) for about a minute or so after shutting the car off... unless I again open the driver's side door. The noise comes on and off, on and off, in any of these scenarios. On for about 3-5 seconds, off for about 3-5 seconds, and on again.
    I used to have another 2004 Prius before, and I remember this sound, but I only remember the sound from pressing the brake to start the car, and right after turning the car off, and only for a few seconds.
    So I am wondering if the two issues are related... perhaps a regenerative braking thing?
    I'd rather do some research before shelling out money to the dealer/mechanic. Any help is appreciated.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Get to the dealer right now. Brakes are not something you want to do a cheap fix on. The Prius brakes are also best left to a qualified PRIUS mechanic.
  3. Patrick Wong
    18,210
    6,513
    Yes, your brake system has a problem and if you can obtain the DTC logged by the skid control ECU (which a generic OBD-II scanner will not be able to read), maybe we can comment on what is causing the problem.
  4. vskid3
    vskid3 Active Member
    773
    228
    Low brake fluid maybe?
  5. EazyMack
    Southern Cal
    Brake fluid is good.
    Definitely sounds like something is charging/pumping, or retracting, or something like that.
    I don't have a scanner. Guess I'll have to get it checked out.
  6. Patrick Wong
    18,210
    6,513
    It could be that the brake pressure accumulator is not maintaining hydraulic pressure, hence the actuator pump is running more than normal.
  7. EazyMack
    Southern Cal
    Would you be able to tell by the sound of it? I could post a video (w/audio of course) if helpful.
  8. Patrick Wong
    18,210
    6,513
    Given your car's described symptoms, I can say that the problem is not going to be something you can deal with yourself so it would be best for you to have the DTC read and a diagnosis provided to you.
  9. EazyMack
    Southern Cal
    Yes, I took it to the dealer (after the ABS, VSC, and red BRAKE lights came on). They told me the brake control power supply needed to be replaced.
    So... I replaced it. Drove it a few miles. Lights still on, still makes that noise every few seconds (see OP). I tried disconnecting & reconnecting the battery as well, but no difference.
    What could I be missing?
  10. EazyMack
    Southern Cal
    The code that came back was C1377, by the way.
  11. Patrick Wong
    18,210
    6,513
    Yes, that does point to the brake control power supply (located next to the 12V battery). Did you install a new part or a used part?
    Since you are continuing to have the same symptoms, check ABS fuses 1, 2, and 3. The wiring harness also is a potential problem. If you have a voltmeter to verify voltages, see techinfo.toyota.com for the repair manual pages which describe how to troubleshoot the wiring connections.
    If you don't find any problems, you probably need to have the DTC retrieved again to see whether the problem is still C1377 or some other issue.
    Stimp likes this.
  12. EazyMack
    Southern Cal
    I installed a used part. What are the odds the used part could have the same problem?
    I will check the fuses. Thank you for the help!
  13. EazyMack
    Southern Cal
    The fuses look fine.
    If it were just the warning lights, I would think they just needed to be cleared again (I did not disconnect the 12V when switching out the brake control power supply)... but it still makes that same noise under the hood every few seconds.
    The dealer was going to charge $690 to swap out the power supply. Does that sound right?
  14. Patrick Wong
    18,210
    6,513
    Did you remove the fuses, one by one, to measure resistance with an ohmmeter? Do not rely upon a visual inspection.
  15. Stimp
    Stimp Member
    53
    North Carolina
    I came up with a C1377 code. Suspected it could be a fuse, just didn't know where to start. Quick search brought me here, and ended up being the 15A ABS fuse.(y)
  16. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Good for you! Excellent. (y)
  17. dolj
    dolj Senior Member
    8,550
    4,343
    Wellington, New Zealand
    The question is why the 15A ABS fuse blew. I wouldn't call it fixed until I knew the answer to that question.
    Patrick Wong likes this.
  18. Stimp
    Stimp Member
    53
    North Carolina
    Because there was a mishap, wires got severed and shorted. Luckily it was very limited, and I got it back to normal. Car was operating just fine with the blown fuse and (!) light. Obviously a safety concern if the ABS didn't operate.The only other fuse that blew was for the door locks, and it was easily diagnosed.
