800 miles on my new v and only 38 MPG - why?!
Discussion in 'Prius v Fuel Economy' started by RayRay, Aug 20, 2013.
  1. RayRay
    RayRay New Member
    2013 Prius v wagon
    I am a new Prius v Five owner, I have had it for 3-1/2 weeks and have put about 800 miles on it. I was very excited about the 40/44 MPG advertised but the average MPG displayed in my car is 38 and has been at that for a while (that is the highest it has been). I live in San Diego, CA with the temperature usually in the 70's - I drive with the windows down most of the time - and in a hilly neighborhood. I drive approximately 30% city & 70% highway. Any ideas why my MPG is not higher? Thank you!
  2. Bingee
    Bingee Member
    210
    62
    Michigan
    Tire pressure ?? Mine were way low when I took delivery
    I'm now running 44 front 42 rear
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    You can check your tire pressure, but most of your mpg results is how you drive and your driving conditions. When it comes to mileage, the driver is the biggest variable, no matter what you drive. If this is your first hybrid, there is a lot of information in various PC forums that discuss driving tips and techniques.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The tires are the second biggest part of the formula. Minimum 38/37 PSI. But mostly you need to get used to driving it for best MPG, so give yourself some time. Also be aware that there are at least 3 different "average MPG" displays available to you, be sure you know which one you're looking at and how to use them all.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I question having the windows down. Much of the Prius advantage at higher speeds is aerodynamics, those are better with the windows up and A/C above 40 MPH.
    Will rolling down windows save fuel or not?
    As a driver, gentle braking, lots of coasting, and combining trips are good plans.
  6. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    One recent poster said his v came standard with Michelin Energy Saver A/S which is a primo MPG tire. That would help.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Keep the windows up on the highway and use the A/C.
    What is the distance of your normal trip?
  8. fuzzy1
    10,603
    usbseawolf2000 likes this.
  9. Aran
    Aran New Member
    24
    2013 Prius v wagon
    Hills could do it
  10. GreyGhost47
    GreyGhost47 Junior Member
    Orange County, CA
    2013 Prius v wagon
    As already stated steep hills are a killer against your avg mpg. I have some pretty big hills (6~10% grade) that I deal with on some of my city travels. I try to find alternate routes that might be a bit more distance but are flatter to help fuel economy. Try and keep the speed down on the freeway if possible.
  11. RayRay
    RayRay New Member
    2013 Prius v wagon
    Thank you all very much for your feedback, tips, and ideas! My house is up a steep hill so I am driving up the hill frequently, which of course means I am in Power Mode. And San Diego is hilly so it's not just my neighborhood when I am forced to go into Power Mode. I checked my tire pressure and it's at 37 PSI now, though the tires say they can be a max of 51. I think I am going to add about 10 lbs and see what happens with my average MPG over the next week or so. My brother owns a Prius and advised me to be gentle on the gas petal and try to stay in Eco Mode as much as possible, which I have been focusing on lately (though it hasn't changed my average MPG from 38, unfortunately). I will keep working at it! Thanks again everyone.
  12. fuzzy1
    10,603
    Power Mode is a personal preference, not something forced by any hills. The available power does not change, only the feel of the gas pedal changes. The car will climb the exact same hills in PWR, ECO, and Normal modes.
    Some of us, especially those of us with less precise motor control, do better with ECO. (It also alters AC and cruise control in ways that should slightly help mpg, in theory.) But others do better with Normal or PWR mode. It is your choice, don't fret this factor too much.
  13. jhinsc
    1,167
    259
    South Carolina
    Not sure if this was mentioned, but have you reset your A and/or B trip mileage meters? I do this at every fill-up so I can see how my mpg average is holding up from one tank to the next. Also register and record your mileage and gas used on fuelly.com to track your progress.
  14. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Very good point in resetting Trip A or B. Also, the OP may be looking at the average MPG while in the ODO setting which will always show the lowest average MPG.
  15. ImeanGreen
    547
    73
    Somewhere out there
    Terrain can also be a big factor when talking about average MPG and hills are the worst case scenario. Check it out in the flats and use cruise control. See what you'll get using trip A or B.
  16. Colin
    Colin Junior Member
    33
    Brake evenly on your way down the hill instead of all at once at the bottom. You'll regen way more power that way and save your friction brakes.
