Do these battery numbers look good?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheLos, Aug 19, 2013.
  1. TheLos
    TheLos Member
    113
    Corona, California
    I'm trying to determine if the battery might be a cause for a difference in mpg's between our two prius's.
    The prius 3 is getting a lower yield compared to our prius 2.
    I did the battery diagnostic I found after searching the forum.
    I ran the test 2 hours after coming home from a 20 mile drive. And I did the test twice, one right after the other.
    First attempt
    Initial reading 11.9
    In Acc mode 11.7
    In Ready 13.5-13.7
    Second attempt
    Initial reading 12.9 but quickly went down to 12.0
    In Acc mode 11.7-11.8
    In Ready 13.5
    Thanks for your time.
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    The better time for more accurate readings is after the car has NOT been run for a number of hours, like overnight. But these numbers show a weak 12V battery. You may get better numbers with a long slow charge. If not, start looking for a replacement.
    TheLos likes this.
  3. Kevine64
    Kevine64 Junior Member
    87
    Those are low numbers? 12v supposed to show like 14v or something?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Near 14v is the charging voltage (in my case 13.8v in a Gen 2 and 14.4v in a v)
    Fully charged would be 12.9v, half charged might be 12.5v
    Under 12 is dead.
    TheLos likes this.
  5. Bill Norton
    Bill Norton Senior Member
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    You might try to find an accurate digital VOM and take a reading at the battery itself.
    If you're really concerned...
    The onboard readout it not accurate.
    Fred_H and TheLos like this.
  6. TheLos
    TheLos Member
    113
    Corona, California
    I tested again as you suggested. Right before leaving for work this morning.
    Initial 11.8
    in ACC 11.4-11.6
    Ready 13.6-13.7
    I'm guessing its time for a new battery?
  7. TheLos
    TheLos Member
    113
    Corona, California
    also, thanks to everyone for all the input! its very appreciated.
  8. TheLos
    TheLos Member
    113
    Corona, California
    anyone know if the 12v battery would be covered under the CPO warranty?
  9. jnet
    jnet Member
    196
    32
    To truly test your battery, you need a battery tester that put a load on your battery and measure the voltage at the same time. If you don't have a tester, then put your car in ACC mode (no READY light) and have someone roll the power windows up and down for you while you measure the voltage. If your battery is healthy, it should read above 12v while the windows are moving.
    If your battery is bad, you could try desulfate the battery. I have a battery charger that claims it could do the job. However, I have never use that feature so I don't know if it will work. You may have to take it to a profession to do this. Basically, the battery will need to hook up to a machine that will give the battery strong electrical pulses.
  10. SteveLee
    645
    180
    North Carolina
    I
    I would try a slow charge overnight with a smart charger or a desulfating charger. It may not help much but it's possible. 3 years is at the low end of the typical 3-5 year lifespan for these 12V. And if it doesn't help much you can expect to start experiencing strange electronic symptoms. It is already placing more stress on the system causing less MPG. I think it's just a matter of time. So you have a little time to research battery options.
  11. edwardob
    edwardob Member
    227
    33
    ireland
    from toyota service manual
    3. INSPECT BATTERY VOLTAGE
    Standard voltage:
    11 to 14 V
    If the voltage is below 11 V, recharge or replace the battery before proceeding to the next step.
  12. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    All the above ONLY makes sense if the battery had been "fully" charged (had enough time to be charged).... for example it takes about an hour driving (or living the car in park) to fully charge a healthy battery after just a few days of unuse ..
    I would suggest to use a battery charger .... or leave the car in parked if it is possible safely ... the HV battery will charge the 12V (ICE will come in only if the HV SOC goes low ) even better checking the chargin voltage with an ODBC scanner, the car would keep 14.5-6V when it thinks the 12V is not fully charged and lower it to about 13.5V when it is "done"
    jnet likes this.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Your battery is done. Do the test first thing in the morning without starting the car not after long drive. After a long drive your seeing the max rate of what the battery can hold for a charge under load. I don't care about that. I want to see the batteries ability to hold a charge over time. 11.7 is bad after long drive. Should be 12.8.
    First thing in the morning yours will be 11.3. Done.
    And yes hammering mpg's.
    Car is either not driven alot. Or bought used at dealer and sat on there lot for a while possible gone dead. Or it has gone dead with you before and you jumped it.
    On Gen II car at about 11.4 it starts throwing an instantaneous red exclamation point on start up. It does not store that code just trying to alert you the battery is bad. Not sure if III does that also.
    Replace with Optima asap. Do everything you can not to allow the battery to go dead and leave you stranded and worse at the hands of an AAA tow truck jumpstart. :eek:
    Avoid the dreaded jump start at all costs. So many Prius's here have incurred $ XXXX. of damage with a bad jumpstart. AS in thousands of dollars not covered under any warranty.
    If you can't change the battery out now and you do get stranded and must use jumper cables hook up the jump cables vry carefully via the underhood jump points. Make sure the donor car does not race its engine. Leave it connected till you can see the interior light come on bright. (shut light off during charging and just flash it on once to check that)
    Disconnect the cables carefully and say a prayer and then boot the car up.
  14. TheLos
    TheLos Member
    113
    Corona, California
    The car was recently purchased, less than 2 weeks ago.
    Last night I took the battery out after not driving all day and I took it over to auto zone where they can test and charge a battery if needed. They hooked it up to their machine and it read 12.4 volts load. I was surprised. I asked if they could try charging it anyway but they said their machine wouldn't charge because it was reading full.
    So I came home and swapped the 12v battery with our other prius which we got a month ago.
    This morning when checking the battery through the nav display it read same as my other battery
    Init 11.9
    ACC 11.8
    Ready 13.6
    My wife gets about 55-56 mpg in her prius. I'm averaging 45-46. This is what prompted me to question the battery after reading the forum. Could the calibration on the nav computer for reading the battery be a little off? Or do I need 2 new batteries?
  15. Bill Norton
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    You need to read the batteries with an accurate digital voltmeter.
    The onboard display is not accurate.
    Didn't your test at auto zone convince you?
    telmo744 likes this.
  16. szgabor
    994
    175
    Oceanside NY
    sounds you are new to prius and prius driving the mpg difference could be or most likely be the driving style .. how about swapping cars with your wife see what can she do with your car ???
    TheLos likes this.
  17. TheLos
    TheLos Member
    113
    Corona, California
    Very new szgabor, I drove hers for a week and averaged 55. I'll just keep an eye on things
  18. Bill Norton
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    The 12V battery can't absorb the amount of energy required to cause a drop in fuel economy.
    It would be a hot smoking mess back there if it did.
    This has been discussed many times on the forums.
    I believe you do have a difference in the two cars.
    A questionable 12V battery would not cause this problem.
    It only boots up the system. Then a DC to DC converter provides the 12V power.
    You could use a clamp-on ammeter to see how much current the 12V battery is consuming when it just sits there and 'floats' on the 12V bus. It should be minimal.
    Good luck finding the difference!
  19. TheLos
    TheLos Member
    113
    Corona, California
    Thanks bill!
