Speaker Replacement...
Discussion in 'Gen 2 Prius Audio and Electronics' started by Bryan267, Aug 5, 2013.
  1. Bryan267
    Bryan267 Junior Member
    33
    Norwich, CT
    Does anyone have a good copy of the years-old speaker replacement guide? The link is no longer active from the thread and I just picked up a set of Hertz components to replace the crap stock JBL.
    Thanks! :)
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
  3. Bryan267
    33
    Norwich, CT
    Yeah. I looked over that. He referenced the guide by sparky so I was hoping to find that.
    No worries now though, I changed out the component set in front last night with a set of Hertz deicis and they sound awesome. Now I gotta buy another set for the back and get a small sub to fill in the low freq for me.
    GS4 'cause I rock like that.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    I found this... also
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    This is the cache left on the internet - but no full file:
    This is the html version of the file http://docs.docstoc.com/pdf/5879625/96374151-072a-49c3-9d87-7d5d271dd125.pdf.
    Google automatically generates html versions of documents as we crawl the web.
    Bryan267 likes this.
  7. Bryan267
    33
    Norwich, CT
    Awesome. Thanks! :D
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Actually this PDF has everything including Tom morrow and Sparky info:
  9. Bryan267
    33
    Norwich, CT
    Even better. That'll help me with the sub later
  10. dj feitl
    dj feitl New Member
    will this info also work with an 07 with JBL?
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    749
    Delaware
    the jbl system has separate wires from the amp for the front tweeters, because the crossovers are built into the amp. otherwise everything is the same. i think the jbl uses 3 ohm speakers; 4 ohm shouldn't hurt the amp when replacing 3 ohms.
    dj feitl likes this.
  12. 69shovlhed
    2,170
    749
    Delaware
    just fyi, today i took the speaker out of my rf door and found that without some sort of spacer or mounting ring, the maximum depth for the front woofer is 2 1/4", unless perhaps one of those neodymium magnet woofers will fit. they have very small diameter magnets just like the junk oe speakers
    the diameter of the cutout is just a hair over 6 1/8". hope this helps someone. i've got to return the woofers i though would fit, or else find a spacer.
    SFO likes this.
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Do u have any pictures of ur install and setup? How did u mount your rear 7" woofers?
  14. 69shovlhed
    2,170
    749
    Delaware
    no pix. the rear speakers are just screwed to the door. plenty of room for a big magnet in the rear doors. i had to drill a couple holes, used spray on insulation on the back of the door skins and i lined the door with duct insulation instead of dynamat cause dynamat is heavy and expensive. the duct insulation i used is 1' wide 1/8" thick foam w/ glue on 1 side and aluminum foil on the other. i have seen other stuff at home depot that would work probably just as good w/ a little 3m spray glue.
    i got some spacers coming for the front door speakers. i'm gonna have to trim the inside of the door panel to get em to fit. drill a few holes... i used the oe wiring cause i didn't need a power amp.
  15. ParryB
    ParryB Junior Member
    Raleigh, North Carolina
    Is it incredibly hard for a novice or rather a first timer to do this DIY Speaker/Components/Console replacement by himself? I can say I have a general clue of things I have to do and I am alright with power tools as well. I guess I need some heads up, guidance and a lot of confidence-boost to take a go at it. I mean there are a few projects that I wanna do to my Pri but the very first one being getting it to thump some more.
  16. 69shovlhed
    2,170
    749
    Delaware
    if you can work a screw driver, drill and ruler, its a piece of cake. rear doors are easier cause you won't need spacers unless you want 8" woofers, even w/ low profile 8"s you'd have to cut the doors or use spacers. you will want 4 ohm speakers.
    to remove the door panels you don't want to get too rough popping the clips out or you'll break the door panel where the clips go on it.
    if you've ever installed car speakers, its not difficult.
    for the fronts, you only have 2.25" clearance when the window is down. i've picked some smaller drivers for the front and still need 1" spacers. i'm gonna have to cut the door panel-- there is a ring that goes around the oe speaker made into the door panel.
