Block Heater
Discussion in 'Prius c Accessories and Modifications' started by RGEYER0, Aug 27, 2013.
  1. RGEYER0
    RGEYER0 Junior Member
    44
    Albuquerque
    2015 Prius c
    Any feedback on the block heaters? Been thinking of getting one for the winter months? Any help would be appreciated!
    Rich
  2. raiste
    raiste New Member
    SC
    Do a search for "block heater" in the Accessories and Modifications area. You'll find at least 2 good threads on this subject. I'd link them, but I don't have enough posts yet. o_O
    Since this is my 4th post, maybe I can link them now:
    maybe not.
    Almost there....
    Now I can. ;)
    C Block Heater
    Block Heater Questions
    djdawn, RGEYER0 and ztanos like this.
  3. RGEYER0
    44
    Albuquerque
    2015 Prius c
    Thank you raiste got my questions answered!
    raiste likes this.
  4. raiste
    raiste New Member
    SC
    No problem, happy to be of help. (y)
  5. maddog61
    maddog61 Junior Member
    44
    Block heater works great, shortens warmup time and u get cabin heat in no time
  6. RGEYER0
    44
    Albuquerque
    2015 Prius c
    I installed mine yesterday, super easy have not used it yet but Im sure Ill be happy I have it this winter!
  7. Species5618w
    Species5618w Member
    140
    Did you have to remove the transmission vent?
  8. RGEYER0
    44
    Albuquerque
    2015 Prius c
    Yes... to get it to line up, but did not have to remove radiator hose
  9. Bohica
    Bohica Junior Member
    I just installed my block heater also. HOWEVER - I broke the vent. The darn thing is half plastic. I super glued it back together and it SEEMS OK but I want a new one. HELP. DOES ANYONE KNOW THE PART NUMBER? The Toyota dealer parts men spent about an hour looking for it. We all gave up.
  10. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Resurrecting this old thread to ask if anyone knows how much power the Prius C block heater draws from the wall socket....?
  11. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    Sean Nelson likes this.
  12. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    400 watts. It's not as powerful as a typical block heater is on a normal car. It doesn't need to be. The Prius C considers itself to be warmed up at 100 degrees - the exact temperature that the block heater holds it at. Now if you want heat - the engine will run until the coolant is above 120. This takes only a minute or two.
  13. Sean Nelson
    421
    182
    OK, 400 watts. Thanks guys!
  14. Mendel Leisk
    41,865
    Regular Prius block heater is 400 too. D.O. for our previous Civic block heater. Two hours is the sweet spot for pretty thorough heat up, anything over one hour is gonna help. It'll raise the coolant temp about 20C of ambient temp. Basically means the car'll be shutting down at lights a lot sooner. How soon depends on time of year and temps.
    Toyota Canada website shows it as an installed accessory for a bit under $250, fwiw.
