Does Emergency Brake use the standard rear disc brakes?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by srivenkat, Aug 29, 2013.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Or has a separate system of brake shoes and drum/disc and such?
  2. srivenkat
    596
    93
    IL
  3. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    For this reason, don't think of the brake as an "emergency brake"; it will not do much if the real brakes fail. It's just a parking brake; something to keep from slipping downhill when you park.
  4. Bill Norton
    Bill Norton Senior Member
    2,143
    734
    MONW, Ks.
    For this reason THINK of it as an EMERGENCY BRAKE.
    It can save your life someday.
    There are Prii having brake failures.
    Practice it once from low speed. If it is a reflex, it could save the day....
