Compatible EVSE from other OEMs?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by uropip, Aug 21, 2013.
  1. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    Is there a list somewhere of EVSEs that are compatible for other makes (Leaf, Volt, Ford, etc) for the bargain shoppers lookin for another EVSE?
    LG-MS870 ? 4
    Most likely Either picking up a Leviton or that Clipper Creek one but if a used OEM one shows up for the right price.. It'd be good to have the info out there
    LG-MS870 ? 4
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I think it was Jeff N and devprius, but they tested a bunch of EVSEs (Leaf, Volt, PiP) and if I recall, the 2011 and earlier Volt EVSEs dont work with the PiP. The 2012 Volt EVSE does and I think its pretty cheap, like $300 or something like that.
    Yeah, Jeff N.. here's his matrix of what was tested and what worked/didnt work
    Charging PIP using Chevy Volt 110V charge cord | Page 2 | PriusChat
    EDIT: The stock Chevy EVSE is $369, it looks like
    2013 Volt Battery Charger Cable - 110V - 23145307 - Electronics - Volt - 2013 - Chevrolet - by Genuine
    EDIT: Sorry, I guess I was wrong.. looks like the 2011-2012 Chevy EVSE didnt work for the PiP at all
  3. F8L
    19,011
    4,081
    Grass Valley, CA.
    The Volt ESEVs are junk. I wouldn't buy one even if the 2013 model works. The 2011-2012 units were really bad. I had my PIP ESEV upgraded to 220v for use on my Volt because I didn't trust my OEM unit. lol
  4. markabele
    5,084
    1,782
    Nebraska
    Really? What goes bad on them?
  5. F8L
    19,011
    4,081
    Grass Valley, CA.
    They mainly stop working and show a fault light. Some have burnt cords or connector prongs. GM apparently switch manufacturers for the 2013 units. If the new ones are indeed made by Clipper Creek then they should be good quality.
    Here is how you can I'd the different model years.
    What the new 2013 L1 EVSE looks like
  6. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    Drake likes this.
  7. F8L
    19,011
    4,081
    Grass Valley, CA.
    The Clipper Creek unit listed above is very well regarded.
  8. Drake
    Drake Junior Member
    71
    Quebec, Canada
    2013 Prius Plug-in
    I have bought the Clipper Creek LCS-25 too and it works fine with my PiP ;)
  9. Francos
    Francos Member
    118
    How much AMP can the PIP draw?
    Another alternative may be Bosch's Power Max $449 with 16A/12 feet cord.
  10. markabele
    5,084
    1,782
    Nebraska
    From the wall? Or during acceleration?
  11. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    First of all, are you talking about a Level 1 (120V) or Level 2 (240V) EVSE?
    An L1 EVSE draws about 12A from the wall. The L2 EVSE will draw about 10A since the car can only pull a maximum of about 2.2 to 2.3 kW.
    I have a Nissan-branded Aerovironment EVSE-RS that works just fine with the PiP (or the RAV4-EV). While it can deliver up to 7.2kW (30A), the PiP still only pulls about 10A.
