Is the C truly a 3rd gen Prius or is it closer to the gen2 in tech?
Discussion in 'Prius c Main Forum' started by jdurston, Feb 2, 2013.
  1. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    The C doesn't come with standard auto on/off headlights... but it can be added.
  2. orenji
    orenji Senior Member
    5,887
    3,490
    Why add it, the car tells you when you left them on, its a simple car, lets leave that way, that is what I love about It, simplicity.
  3. rfruth
    rfruth Member
    394
    Houston, Tx
    Good stuff, tnx all ! - Question, is there a fan to help cool the high voltage battery, if so does this cooling fan continue to run even after the car is off ? (again if so the 12v battery must get a real workout)
  4. clgutierrez
    clgutierrez Junior Member
    51
    17
    There is a fan below rear left seat. It stops once you stop/turn off the car.
    Sent ?
  5. rfruth
    rfruth Member
    394
    Houston, Tx
    Good to hear, suspect in MY 2015 the Li-ion batteries will need additional cooling, I want the old stuff !
  6. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    My C is wearing in well as I now am getting 60+mpg (computer indicated) on my daily 60 mile round trip commute. Of course the weather is warm now.
    On the other hand, my Gen II is running better than ever. It has 60k miles now and last weekend we drove it to the beach and back. About 350 miles and the computer indicated 56+ mpg when we got home.
    I really like both of my cars. But I must say the Gen II feels and sounds more solid than my C (which I really do love).
  7. mahout
    mahout Active Member
    655
    116
    NC
    First, let me say I moved to a Prius C from a Civic Hybrid and I got thme mpg as you - 38 mpg average.
    My prius C2
    First let me say I moved from operating an Insight 2001, and 2 Civic hybrids 2004's, to a Prius C2. The Insight got 45 to 52 mpg, the Civics got 38 to 44 mpg, and the Prius C2 gets 48 mph besides having no attempts to maximize mpg. All are in videos on you tube.
    Then only Toyota Engineering can answer your questions and probably will not. Any comparison of battery technology between gen 3 Prius and Prius C could be expected but that is likely only known by TE asa it should be.
    My recommendation is move up to the Prius C.
  8. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    I have a Gen III and a C, love them both... they both have their pros and cons
