Does A/C impact MPG?
Discussion in 'Gen 3 Prius Fuel Economy' started by PriusInCA, Aug 27, 2013.
  1. PriusInCA
    PriusInCA Junior Member
    Clearly running the A/C in a conventional car impacts the mpg. Does it have much impact on a Prius Gen 3? I am not certain. I believe the A/C is driven off the traction battery. Yet...if it does, the traction battery would required to be recharged, which may mean running the car? Or maybe it is just generated from the braking.
    Any thoughts?
  2. vday
    vday Member
    312
    Israel
    It will effect the mileage - more so in the city and less so on the highway
  3. sisharp
    sisharp Member
    46
    29
    South Carolina
    Try using the search function. There have been many discussions on this.
  4. jnet
    jnet Member
    196
    32
    short answer - yes
    how much impact? it depends on your temp setting and outside temp
  5. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I see on mine it kills it but 4mpg not a big deal
  6. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
  7. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You should run the AC to keep you AND the HV battery cool in hot weather as heat is the enemy of a long-lived HV battery.
    JeffD
    F8L and jdcollins5 like this.
  8. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Who cares. Stay cool.:cool:
  9. TheLos
    TheLos Member
    113
    Corona, California
  10. Gabriel Perez
    Gabriel Perez New Member
    Pasco, Wa.
    I have been running my A/C 50% of the time, and and and getting 54.7 mpg and still driving, 151 miles till the next gas fill up. If I am lucky, I should get into the 500 club. My next goal is to do 550 or 600 club.
  11. Jay Gloab
    Jay Gloab Junior Member
    27
    I should have kept going on my second-to-last tank, I was at 503 miles and it wasn't blinking yet. But I was in the Outer Banks and I didn't want to try to buy gas on the way out of there, so I filled up a couple days early. The computer was reporting something like 57 MPG then, after a long highway trip and a few short trips with A/C running the whole way.
  12. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Only if you use it! The more you do, the bigger the hit!
    F8L likes this.
  13. Gouda Cheez
    Gouda Cheez Junior Member
    73
    So far I've noticed no ill effects to my MPG when using my AC. Still averaging 50-51 MPG.
  14. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    As mentioned, A/C impact on MPG is dependent on usage/temperature.
    All components in the car ultimately receive energy from gasoline (chemical to mechanical to electrical)
  15. tplife
    tplife Junior Member
    85
    24
    SoCal
    Haha, the 3-4 mpg is laughable as people driving over 40 with the windows open get less mileage than with the AC on due to aerodynamics (like with any other automobile, hybrid or otherwise). So yeah, you get better mileage with the AC off...Just don't open the windows! :ROFLMAO:
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    This is incorrect.
  17. tplife
    85
    24
    SoCal
  18. F8L
    19,011
    4,083
    Grass Valley, CA.
    Try doing test with your Prius. You'll find that driving with 2 windows down creates less of a mpg hit than using the A/C, particularly during short trips. I've done the test myself many many times. This test has been done by a friend (who works for CaRB in the EV division) in his Civic Hybrid and he found the same results I did.
    It is important to make a distinction between the vehicle in question and how many windows are down. With every window down I would agree the A/C is likely less of a hit but who drives like that on the freeway? Every vehicle has different aerodynamic signatures around the window areas. The Prius is still VERY aerodynamic with just the drivers side front window and the passenger side rear window down. That's enough to blow quite a bit of cooler air through the car without upsetting aerodynamics much. Try 4 windows down on a Volt and the wind buffeting is so bad you would expect the back hatch to pop off! :)
  19. Mendel Leisk
    41,824
    We drive a lot without the A/C in hot weather. At slow speeds have the windows fully rolled down, but as speed picks up start bring them back up. I think there's less and less aero impact if they're just cracked a few inches.
    I do feel reduced glide or something similar, when A/C's running.
  20. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    Yea. The less you use it and the higher you set the desired temperature, the better gas mileage you will get. I drive around with it on 79 or 80 sometimes when it's 90 degrees out, and the air still feels cold. Don't be that person who sets it at 65 when it's 90 outside, you will drain the hell out of your HV battery.
