Perma EV Mode?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Robroy, Sep 7, 2013.
  1. Robroy
    Robroy Junior Member
    I
    I have a 2010 Prius base and I would like to keep it EV mode more often. Unless I crawl, the car uses ICE almost instantly. I do deliveries and make approximately 120 stops in 3 hours, so charging shouldn't be much of an issue. I've done some research here, but I haven't found something that would give me direction on how to do this. I read where in Europe/Japan they have a EV switch that keeps the ICE from kicking in?
    Please help, much appreciated in advance! :)
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    There's not much point in trying to stay in EV. 1) Its only good for a short distance. 2) Emphasizing EV is less efficient than the computer's choice of EV/ICE because of the conversion losses in charging and discharging the battery.
    F8L likes this.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't know.
    What do you mean by use's ICE almost instantly? Upon acceleration to gain speed and torque it is going to kick into ICE pretty quickly.
    From a stop, mine kicks into ICE synergy pretty quickly. This is a hybrid...not a full electric. Usually if the vehicle is warmed up and the battery charged, once you reach whatever speed, you can usually pull back and drop it into EV mode, if the speeds are low enough.
    If you are making 120 stops in 3 hours, and constantly turning the vehicle On and Off...that may explain why the ICE is running so much. If the vehicle is never really allowed to fully warm up and/or is in constant state of warm up.
    In any case as pointed out, you wouldn't want to be in full EV mode all the time anyway. Do you actually turn the vehicle off at all these stops? The Prius does best when allowed to be fully warmed up, and in combining short trips.
    Jeffrey Jessup likes this.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    EV is not good for 120 stops in 3 hours. The Prius already knows what it's doing.
    ewxlt66 likes this.
  5. bisco
    52,286
    welcome to priuschat! you may be better off with a pip. also, someone here has an 07 with 8kw engineer system for private sale. all the best!(y)
  6. Robroy
    I
    Thanks all. So in future I'll consider PIP.
  7. Robroy
    I
    Question on the stops, should I idle or turn off each time?
  8. fuzzy1
    10,588
    Unlike earlier US models, the 2010 already has an EV switch. When the car overrides that switch and turns on the ICE, it is doing so for good reason.
    If conditions are safe to do so, let the car idle during stops. As soon as it is warm enough for the EV mode portion that is available, it will auto-stop the ICE on its own. Then it won't need to go through the warmup cycle again.
    When the ICE turns on by itself later, it means any of the following:
    * The HV battery level has dropped too low, and needs to be recharged;
    * The ICE coolant temperature has fallen too low, and must be warmed;
    * The exhaust catalyst temperature has fallen too low, and must be warmed;
    * You are asking for more acceleration than the EV mode alone can supply; or
    * You are exceeding the EV-only mode speed.
  9. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    The car can handle extended "idling" ( in P with Ready light on) with no problems. Your mileage will be better if you can leave it in idle.
