Traded 2013 Volt for New Prius HB
Discussion in 'Gen 3 Prius Main Forum' started by rudiger, Sep 7, 2013.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    IIRC, a Volt owner has to keep the car for a minimum time to not run afoul of the tax rebate laws. How did that play out for you Rudiger ?
    Also, if you do not mind sharing, what was the the total cost for the Volt experience ?
    Volt Purchase Price
    + trade-in deal
    = Prius + one year of Volt use
  2. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    $35k (Volt Price)
    $4k (Difference)
    $39k
    But I had a trade on the Volt, which I think was like $22k. So, I suppose guess it cost me $17k, less the tax credit, makes it under $10k.
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Thanks for detailed info!
    I would like to " buy American" but had several GM vehicles in the past and all were unreliable ( our Buick's nickname: "Calamity Jane"). Toyota has made a clear corporate commitment to hybrid drives across a range of vehicles, whereas I still wonder if GM is really committed to EVs or the Volt is more a PR device. Saw rumor that Gen 4 Prius might be made in US, so maybe I can "buy American" that way.
  4. John H
    John H Senior Member
    2,208
    558
    It sounds to me like you got paid $3,500 to drive the Volt for a year. $7,500 tax credit - $4,000 = $3,500.
    Sweet!
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    lol
    By your arithmetic he was paid $3,500 to own the Volt for a year. ;)
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    Sounds about right if you get to keep the tax rebate. Do you ?
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    You mean 8 amps, NOT kW. The Volt only has a 3.3 kW onboard charger. Heck, my '13 Leaf has the optional 6 kW OBC.
    As for the crappy L1 EVSEs included w/the Volt, yeah, I'd heard plenty about that. I haven't kept up w/all the revisions and current situation.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    I thought he was calculating 8 Amp * 110 Volt = under 9 kW
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    I have OBC envy. :p
  10. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    You mean, under 0.9 kW.
    I would be so sure about the i3 having "100 mile EV range". See i3 Driving Dynamics: What A Disappointment - Page 4.
    The '13 Leaf has an inflated range of 200 km (124 miles) on some inflated European cycle. Ask any non-hypermiler Leaf owner how far they can go, realistically...
    The i3 gets slightly fewer miles on that inflated cycle than the Leaf, then it'll probably get ~70 miles of range on the EPA test, likely less than 75.
    Yep. From browsing a few other GM forums of vehicles w/worse to far worse reliability records than the Volt (which IIRC has a surprisingly good reliability record, so far), I've seen similar stuff and there will be he GM defenders and fanboys who will be in total denial about a poor reliability record, bashing Toyota and Honda, etc. Seems true of VW fanboys as well.
  11. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Yep I was wrong, 8amps not kw.
    I've used my L1 EVSE almost exclusively.. not had a problem yet. (I traded it in an upgraded model during the battery tunnel enhancement program. They increased the gauge of the pig tail). But ~20K miles and no problems of any kind (car or chargers).
    Most people with problem on gm-volt were using it at work or other places.. it may not tolerate unclean power. The fuse could easily be the issue. The really "cheap" version was the SPX L2.. which used very small wires for a L2.. then again when it was offerecen it was $400, compared to other selling at $800-1200 so people knew it was "cheaper".
    No I was just wrong. (. 8 amps * 110v = 880 watts.. not kw big difference).
  12. john1701a
    john1701a Prius Guru
    12,832
    5,308
    58
    45% of the parts in Volt are US/Canadian. 18% is from Japan. 17% is from Korea. The other 20% is from elsewhere.
    WE0H likes this.
  13. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I'm talking about stuff like GM replacing almost all Chevrolet Volt power cords and comments by the OP of The anatomy of a Volt EVSE.
  14. rudiger
    696
    45
    Cincinnati, OH
    The original 120v L1 portable EVSE in the 2011-2012 Volt was made by Lear, the same manufacturer of the craptacular 240v L2 SPX EVSE that has issues with failing not long after the warranty expires. Fortunately, it doesn't appear that the 2011-2012 Lear-made L1 EVSE has experienced any issues (well, except for the small gauge pigtail).
    The 2013 and newer L1 portable EVSE included with all Volts is now made by Clipper Creek. As the 240v L2 EVSEs made by Clipper Creek seem reliable (they also have a three warranty), it could be inferred that those later L1 Volt EVSEs made by Clipper Creek are similarly of higher quality than the Lear-made units.
    drinnovation likes this.
  15. rudiger
    696
    45
    Cincinnati, OH
    I was just quoting what I've read BMW is claiming will be the range for the i3. Very few (if any) are in the hands of consumers. Even if BMW's claims are accurate, 200 miles, total, on both gas and electric is still quite limiting. Unlike the Volt, which can be driven over long distances (although it's a chore having to refuel frequently), I can't imagine anyone trying it with an i3.
    VW continues to sell vehicles primarily due to an exceptionally well-run marketing department. Some of the most memorable auto commercials and ads ever produced have been for VWs. At least that's my theory. Plus, on those rare occasions when everything's working correctly (like when they're brand-new), VW products nearly always get stellar reviews.
  16. rudiger
    696
    45
    Cincinnati, OH
    Here are some additions to my list of Volt gripes (I'll refrain from posting them over at gm-volt.com because I'm pretty much persona non grata over there now and have tired of the 'why are you still here?' type responses):
    1. Minor: The Prius radio (at least in the non-Nav units) still has a 'scan' button. I thought it was gone because it used to be a separate, dedicated button in the radio bezel but, low and behold, there it was on the MFD. Probably not much of an issue for all but us ADHD types. All I know is it was a PIA to constantly hit 'auto-store' to find radio stations in the Volt.
    2. Not so minor: The Prius still has an actual spare tire, even if it is a space-saver. The Volt is yet another of those vehicles that, in the interest of saving weight (and money), doesn't have any kind of spare but, instead, has one of those cheap tire inflators with the goopy sealant. What GM doesn't tell you is that if you use the goop (you can run the inflator with or without it), while it's pretty much ineffective, anyway, it also has the high probability of ruining the TPMS sensor installed on the wheel. Some of those Volt owners who have had flats and tried to inflate using the goop, ended up coughing up around $1000 to get everything replaced and fixed. That's pretty damn expensive for a single flat tire when one considers that with a vehicle that has a real spare (like the Prius), the cost to fix a flat will be substantially...less.
    3. Ground clearance. I hope that guy who started the thread whining about the low ground clearance of the Prius and switching to a Subaru never considers getting a Volt. Those things sit lower to the ground than a Prius, in more ways than one. The seating position is lower, and the car itself seems lower. For certain, GM put a lower than normal front air dam on the cars to increase mileage efficiency. As you can imagine, it's done at the cost of constantly scraping the pavement over minor dips and inclines. GM knew it would be an issue, too, because they offer an extra-cost, replacement, short air dam (it's not that expensive and easy to change). And, of course, the short air dam is theorized to cost a few miles in both fuel mileage and electric range. But even with the short air dam, the thing still seems to scrape a whole lot more than the Prius.
  17. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Yes, I've heard that some of the moderators at gm-volt.com are rather intolerant of negativity towards GM and/or the Volt.
    As for i3, it will not go on sale in the US until 2nd quarter of 2014 per BMW i3 gets official worldwide [UPDATE, w/video] - Autoblog. if I'm not mistaken, it hasn't gone on sale yet in any market.
    As for VW, that's a decent theory. It's strange that amongst some people, VW has a positive aura/draw about it.
  18. El Dobro
    El Dobro A Member
    7,093
    3,271
    Yep, just like a train wreck.
  19. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Is it a "cheap tire inflator"? Actually, I think it's nicely designed and it seems to work well.
    I had a puncture and leak in the tread of one of my original Fuel Max tires a week ago after 57,000 miles of trouble free driving. I had been driving on a gravel road to get to a trailhead for a hike. It was a Sunday and all the local tire stores were closed.
    I used the tire goo for the first time and it worked great. It couldn't have been simpler. I switched the Volt's 12v tire pump to the "fix" position, inflated, drove around for 5 miles, adjusted the final pressure level and I was good to go up to 55 mph for the next 100 miles. About 90 miles and 24 hours later, I pulled into a tire shop and bought a new set of tires (I was planning for that before winter anyway). My TPMS was just fine.
    I haven't read of any (multiple?) Volt owners having to pay "$1,000" to replace a TPMS sensor etc. after using the tire goo but I'm sure someone got ripped off somewhere. That story sounds rather extreme.
    UPDATE: I suspect you are thinking of the nonsense thread I have linked to below. The OP there tossed around some fevered and baseless assertions including his own "guesstimate" of $500 which wasn't based on anything he actually paid. The TPMS sensors are apparently $50-$100 retail and some people have said in that (and related threads) that any TPMS damage attributed to use of GM's goo cartridge has been covered by GM warranty and isn't supposed to happen normally.
    Tire shops apparently don't like having to clean up the tire or wheel rim after the goo has been used but they do it anyway on a routine basis. Various people in various threads also assert that tire goo damages TPMS sensors in various ways but they never seem to provide sources to back up the assertion. It's hard to tell if the claims were valid with older goo formulations or TPMS designs or if it's all just "common sense" that is assumed to be true without any empirical grounding.
    Source link:
    DO NOT USE YOUR FLAT TIRE REPAIR GEL!!!!!!
    Yes, the soft rubber scraping is a bit annoying once or twice a day. At least a year or two ago the shorter air dam was free if you asked for it to be installed. A number of people on gm-volt.com had that done and reported little or no perceivable loss in efficiency. There must be some efficiency loss or GM wouldn't have bothered with the longer one but I see no evidence that it "costs a few miles".
  20. El Dobro
    El Dobro A Member
    7,093
    3,271
    There's threads here about the lack of a spare for the PiP and the high price of having a flat replaced, so it's not exclusive to the Volt. ;)
