What makes this car so good. ?
Discussion in 'Prius c Main Forum' started by Andyprius1, Sep 8, 2013.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Bought on Friday, no CC, combined driving including the foothills of the Sierra Nevada Mountain Range. Distance: 107 miles / mpg: 67. The engine is far from being broken in, also, I sat in the car for a hour with the AC on and the engine cycling on/off every 5 minutes. I believe these stats beat anything my 2005 could do. Or what the PIP can do. ( Excluding. EV from outlet charging )
  2. orenji
    orenji Senior Member
    5,887
    3,488
    It may be more broken in than you think, with all that mountain driving and letting it run for an hour with A/C on........:(
  3. bisco
    51,843
    weight?
    HaroldW likes this.
  4. Andyprius1
    2,327
    859
    Cool CA
    Running the AC in the accessory mode did not hurt it at all, it cycled on and off in a regular manner all the time maintaining about two bars. That alone is a tremendous improvement over the Gen 2 and 3. Also if you do not have a Prius C you know not whereof you speak. Also, I spoke of the foothills, not Mountain driving, although I have no doubt that the car can handle mountains too.
  5. Andyprius1
    2,327
    859
    Cool CA
    . Hello Bisco, You do wander around a bit, YES, weight must be a big factor, it seems to regenerate better, the thing I discussed with the AC, one dare not do in a Gen 2 or 3. It was over 100 degrees and I felt like being a comfortable 78 studying my owners manual and resetting the #s because the dealer did not do it. Now to handle various 30-60 mile excursions the C does the trick and I can save the PIP for all electric.
  6. Andyprius1
    2,327
    859
    Cool CA
    This all saves me from having to buy a Tesla.
  7. Andyprius1
    2,327
    859
    Cool CA
    . My apologies Orenji I see you do have a Prius C.
  8. orenji
    5,887
    3,488
    No worries. Hope you enjoy your new C :)
    Andyprius1 likes this.
  9. bisco
    51,843
    how many pri does a tesla beget?:)
    TatumRob likes this.
  10. CraigB
    CraigB Member
    205
    96
    SF Bay Area, CA
    Tesla probably won't be putting out their own cars in 10-years....they'll most likely excel with designing their platform for other manufacturers (as they do today). While they have made out well this past year, their cars are too darn difficult to build and time consuming. Not to mention that software changes almost weekly in some cases and they can't pre-build some of their parts based on technology advances.
    I see at least 3-5 a day here in the Silcon Valley....dime a dozen, but they do look bad nice person. I have an older home so I'd have to have the electrical just to have any type of electric car, lol. I'll stick to my baby steps and highly enjoy what I have for the next 5-years or so.
  11. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    When my wife shops and I'm waiting in the car if required I leave my gen 2 on ready with the A/C on. All it does is drop the FE a bit! These C's have my attention as well!:( H
  12. Andyprius1
    2,327
    859
    Cool CA
    That is one of the key points, curb weight = 2500 lbs. I think the PIP is something over 3000.
  13. bisco
    51,843
    congrats on the new ride, pip and C, i have pip and truck, you're making me look bad!:cool:
  14. Andyprius1
    2,327
    859
    Cool CA
    TY, I am not sure which one I like the best. And Toy is planning on improvements.........
  15. bisco
    51,843
    is it as comfortable as pip? my joints get crankier everyday.:X3:
  16. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    I'd never leave a car A/C on for more than 5 minutes if the car was parked. Might not hurt the engine, but it will hurt the air conditioner because nothing is running over the compressor.
  17. HaroldW
    716
    95
    I don't do it often!:( H
  18. Andyprius1
    2,327
    859
    Cool CA
    It is hard to say, no trips yet.
  19. patsparks
    10,664
    567
    Adelaide South Australia
    There is at least 1 fan to push air over the condensor and the "compressor".
    You know what makes all Prius brilliant? Toyota do!!
    ztanos and Andyprius1 like this.
  20. Andyprius1
    2,327
    859
    Cool CA
    You will have to translate that into English for me. You mean like a field of Joggers " running over " the hood! Excuse me, Bonnet. I believe that in all the Prii, one can run the AC safely, and the engine will cycle on/off periodically to adjust for the AC load, IN READY. However in the C, I was able to go into the first position with the key and run the AC and have the engine cycle to keep the charge at a nominal level. The car appeared to be in Accesory mode. I will have to look closer and make sure that is correct. Cheers.
