HV Battery Blower Maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edthefox5, Sep 9, 2013.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Took the Traction Battery blower out today first time since I bought the car new and have 65,000 miles.
    Even though my sheddy dog is always with me the blower had no dog hair and only a very light dust on it. Apparently my blower hardly ever turns on and when it does its always in low speed. I have never heard it run. Which means:
    A---I take it easy on the car.
    B---The car has never seen a hill in its life.
    C---Cabin is always cold. AC always on. Windows never down.
    I think its B & C that matter most to the battery.
    When you clean it make sure you get the dust under the plastic squirrel age. Its in between the cage and the motor. You can see it through the plastic cage.
    Btw, since its out lubricate it. Take the back sticker off revealing the end spindle.
    Its in a bearing there. Use 20 weight oil and oil it right there and spin the cage then let it sit for a while. 3in1 makes 20 weight oil sold as electric motor lube in a little 3in1 dispenser with tiny spout. Handy. Same oil you would use on the big fan in your outside home condenser. Really helped free up the motor.
    Since my car is getting old and to help the traction battery I am going to hook up an external power supply and run the motor in low when the car is in ready. Bypass the existing blower control module and relay. Some forced cooling if you will. This was discussed a bit already and the negative is what happens if the battery needs max cooling and your stuck in low. I don't think that's going to happen in my particular scenario. Towards the blower always on I also installed an external filter over the vent next to the back seat. Surrounded the vent with double sided tape and cut out a square of filter media and stuck it on. Looks good and hopefully since the blower will always be on save me a cleaning trip of the cage.
    Pain is there's no "Ready" leg in the trunk to trigger an on/off for the supply. Thinking I'll tap off the cigarette lighter and run that wire back there.
    ftl likes this.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Excellent post.
    With you living in Florida I can just about assure you that your battery blower motor runs. The motor is very quiet and hard to hear at low speeds. If you have a SGII or other OBDII device you can monitor this along with the battery fan speed.
    I have thought about connecting an external power supply to my battery fan also. The existing fan controls work well as long as the car is in Ready mode. Once you stop the car, especially after city start/stop driving, the battery temps are elevated and they will continue to climb when the car is turned off and the fan stops. I have seen the battery temps increase 5-10F after the car sits for an hour or so.
    One guy on here came up with a printed circuit board with an adjustable timer so he could run his fan for 15 to 30 minutes after the car is stopped. Another guy hooked his up to an external power supply and runs his fan at high speed all of the time while the car is on.
    My guess is that Toyota had a trade-off between running the battery fan after the car was off and the additional drain on the 12V battery and chose to not run the battery fan.
    edthefox5 likes this.
  3. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Thanks,
    I modified my post to "hardly" ever turns on. It clearly has been on but not alot based on the dust on it. Thank you.
    I plan on an external 12 supply with adj. and run the fan on low not full blast when in READY. Just moving some air will help alot. Its a pretty big fan maybe an amp or 2 and may effect mpg. Now the fan's blower control module and relay are controlled by the Battery ECU. I really don't want to cut into that circuit.
    Have to do some R & D here.
  4. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I wonder if it would be possible to connect a small low power solar panel (through a diode) so that it operated in parallel with the existing controller. I was thinking of something with just enough juice to keep it ticking over when it's parked in the sun.
  5. BFAyer
    BFAyer Junior Member
    Gloucester, VA.
    If you have a scangauge 2 you can set it up to run the fan at any speed you want.
    SFO and edthefox5 like this.
  6. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Oh I have a Scangauge but never sent it out to be upgraded. That's awesome. Thank you very much!!!
  7. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes, I have tested the scangauge control of the battery fan speeds. It works fine. Running the fan constantly at a low speed should help with the battery temps. I just think the battery ECU control of the battery fan works OK.
    The only problem that I see is that the fan needs to run for some period of time after the car stops to keep the temps from continuing to rise.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Of course you're free to modify and adapt your vehicle in any manner you wish.
    But it seems to me, you have 65,000 miles on a 6 model year old vehicle. Your own inspection revealed little dirt build up in the fan. You say you've rarely heard it turn on. You haven't had a problem so far.
    I wouldn't make the assumption that any changes to the operating system in regards to the HV battery blower need to be made. Kind of seems like the typically American attitude that "more" is always better.
    Of course I don't live in Florida...The Pacific Northwest is much more forgiving in terms of surrounding cooler temperatures.
  9. BFAyer
    Gloucester, VA.
    If you have to run the blower fan after the Prius is powered off, you can get a Hella time delay relay that can delay from 1 to 900 seconds.
    Without drawing it out I think if you hooked up a NC relay to 12V switched feeding the time delay relay it should work fine.
    When you power off the car the NC relay would close and would supply 12 volts to the time delay relay running the blower for whatever length of time you set.
    When you power the car on, the NC relay would open and the system would return to normal.
  10. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Do you have any info on the Hella time delay relay?
    One thing that I would add to your description above would be to add a NO relay contact to the blower feed from the ECU so as not to backfeed the ECU while supplying external 12V to the blower.
  11. BFAyer
    Gloucester, VA.
    Hella 996152131. They cost about $30.
    I used one in my jeep to turn my headlights off after I parked it. Worked better than jump starting it all the time :)
    SFO and jdcollins5 like this.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    One note for anyone thinking about running the HV battery fan blower motor with an external power supply, I took the following readings while testing the SGII XGauges:
    BFM = 1, CF0 = 34% and VMF = 1.3V
    BFM = 2, CF0 = 41% and VMF = 2.0V
    BFM = 3, CF0 = 48% and VMF = 2.5V
    BFM = 4, CF0 = 55% and VMF = 3.0V
    BFM = 5, CF0 = 63% and VMF = 3.5V
    BFM = 6, CF0 = 72% and VMF = 4.0V
    As you can see at the highest battery fan speed at BFM (battery fan mode) = 6, the voltage to the blower fan is only 4.0V. I am not sure what connecting 12V directly to the blower fan motor would do. I am sure it would be extremely loud since at BFM=6 the fan was pretty loud.​
    Of course this assumes that the SGII XGauge feedback is correct.
  13. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I wonder if those voltages could be right. Prii-dash shows my fan voltage to hang around 6-9 volts, and the sound is not audible unless I put my head close to the vent.
  14. BFAyer
    Gloucester, VA.
    Interesting. Assuming that is correct, you can get a DC step down module on DX for about $10. Just add it to the output of the time delay relay.
    Then you could dial in whatever speed you would like after shut down.
    jdcollins5 likes this.
  15. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I see you have a 2009. I have the 2010. I wonder if this has to do with the difference in the two fan controls. I know there were some basic differences between the Gen II and Gen III battery systems.
    I cannot hear my fan normally since the highest I have seen it is BFM=4. When I tested it with the SGII and got up to BFM=6 I could hear the fan close to the vent, as you said.
    Without testing with a voltmeter I have no idea whether these voltages are right or not. All of the other SGII data for the battery fan seems to be correct. I know I have seen others report similar data for the battery fan speeds based on HV battery temps.
  16. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I just checked the Repair Manual for my car and it lists the battery fan voltage range as 0-5V. It also lists a test for Battery Fan Mode 1 = 1.0-1.4V. The SGII value for Mode 1 = 1.3V. So it appears these are correct voltages.
  17. nh7o
    1,686
    340
    Hawaii
    OK JD, interesting. That does look like a difference in the two models. A curiously low voltage for a fan motor. I usually associate low voltage motors with reduced efficiency, so they must have had some compelling reason to change.
  18. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes, I was surprised with the lower voltage. I was expecting a range from 0-12V.
  19. edthefox5
    10,096
    4,832
    Clearwater, Florida
    My 07 has a 12 volt blower motor. The Gen III must have a 5 volt motor.
