If a Prius has the center display (mpg, camera, etc.), is that a higher level Prius?
Discussion in 'Gen 2 Prius Main Forum' started by buck_rogers, Sep 9, 2013.
  1. buck_rogers
    buck_rogers Junior Member
    44
    I saw one that is Prius Touring, and I read that is just a cut above the base. But then I found one for sale and it has the backup camera and the middle "screen" display that has the consumption and all that. It is a 2008.
    Is this a higher trim level or just a lower end with more options, whatever that means.
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    here is a decsription of the various trims
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You're completely backwards there. It is excusable since Toyota made it very confusing.
    The "Touring" model has extra features over the base trim package it is in. However, many dealers and sellers have no idea what the heck they have and misrepresent the models as Tourings when they are not. The touring models come with larger diameter wheels, a stiffer chassis and a few minor handling things in addition to the interior trim options. If you are in the US, the Touring is generally the package #6 + touring package.
    2008 models come in 6 standard flavours:
    They all have the MFD (the screen in the middle). If you have navigation then you will also see an extra button on the left side of the screen that shows the map data when you press it and an extra button on the steering wheel controls for the map feature. Other than that they look the same.
  4. buck_rogers
    44
  5. Patrick Wong
    18,210
    6,517
    No, because it has 15" aluminum wheels and the standard-sized rear spoiler.
    The Touring has 16" aluminum wheels and a larger spoiler. It also has different struts/shocks.
  6. buck_rogers
    44
    Oh man. So they were pulling something over on me then. I'm glad I asked. Thanks for saving me. So it is low end? Base? Rough ride?
  7. buck_rogers
    44
    I see it. I don't want to get ripped off. The touring has a spoiler that looks like this
    base,
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Either that or they really didn't know. It is pretty confusing.
    Figure it out look at the pictures and the chart. It has SKS because the little black buttons on the hatch and two front doors. Therefore it is above a package 1, not a base. Looking at the MFD, there is no navigation button so it is not a package 5 or 6. It doesn't seem to have fog lights, so it is a package 1-3. So that leaves packages #2 and #3.
    So if it has the autodimming mirror or 6-disk CD changer, it is a package #3. Otherwise it is a package #2. To me it looks like a package #2. Non touring.
    The touring has a rougher ride. To american's "better handling" means a stiff suspension so Toyota, like BMW and Audi, obliged.
  9. fuzzy1
    10,678
    We've seen that the fraction of Touring Prii on the used car market far exceeds the fraction that Toyota actually built. This is a very common mislabeling.
    My quick tell is to look at the wheel covers, presuming no one swapped wheels. Touring had 7 spokes, regular GenIIs had 6 spokes. GenIII liftbacks have 5 spokes.
    xpcman likes this.
  10. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    here is what the wheel cover looks like for the regular Prius and the Touring model
  11. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    hope this picture looks better
  12. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Over here in the UK, the Touring Gen II Prius is called the "T Spirit", then we have in descending levels of extras, the T4 and T3 models. While I'm pretty sure none of the T3's have SATNAV installed in the MFD, perplexingly, T4's have been known to come with the SATNAV package.
    However, to the best of my knowledge, ALL Gen II T Spirit's in the UK definitely come with SATNAV by default.
    Judging by the lack of the NAV extra buttons on MDF of the so called Touring Prius in the pictures - and the lack of fog lights too, I would wager that sadly, it's definitely NOT a Touring model.
