How to get 95 mpg
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Priusmpg, Sep 9, 2013.
  1. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Hello I'm new to prius plugin but I had a 2010 prius that gave me 50mpg I drove it for 184000 miles that's right I was a courier It was a great car, I now got a 2013 plugin prius which I was wondering how to achieve the 95 mpg like which mode to drive the car in how long to charge it before leaving I have route that is 100 miles both ways I drive it every day
    51,479
    welcome to priuschat! about the best you can do on a regular basis is 70 mpg or so. plug it in until it's done charging.
    all the best!(y)
    Priusmpg likes this.
  3. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Thanks. What is that 95 mpge on the sticker about
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    That's what the car gets in EV mode according to EPA. They use 33.7 kWh = 1 gallon of gas. I have a 103 mile roundtrip drive to work and I get up to 100 mpg. But usually average around 80 mpg.
  5. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    Last week's trip consisting of two +200 mile trips without recharging both resulted averages around 60 MPG for me.
    The system is remarkably efficient without even plugging in. When I do, it improves MPG even more. With lots of miles, you won't see a huge number increase though. The 4.4 kWh battery-pack get only deliver so much electricity.
    You'll get a benefit from it regardless, but don't expect MPG like what others with much shorter routine drives experience.
    CicilyMJ likes this.
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I've seen some battery extension packs that sit in the trunk are has anyone used that on a
    Plug in ?
  7. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Yeah, with a commute that long, depending on road conditions and speed, I'd expect mid 50's to low 60's best without resorting to hypermiling tactics that will get old fast with that much driving.
    I would look for any possibility to charge on each end of your trips which will help a lot. Use the EV/HV button to conserve battery for city sections of your trip - use the HV for highways and hills.
  8. bisco
    51,479
    those are made up by genius inventor's and can only be used and maintained by nasa type engineer's. there's nothing available for us poor folks. but you can get a good deal on a chevy volt these days and they go 40 miles on a charge.
    mmmodem likes this.
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Wow I just bought a Pip think it would help me in my commute on Saturday and It turned out to be a bust. I am in California is their any way I can take it back and get a regular pruis I have only put 200 miles on it
  10. bisco
    51,479
    of course, and the good new is the regular prius is cheaper, so you'll get that and they'll cut you a check. (minus depreciation)
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    How much would think it has depreciated I actually just got the Windows tinted
  12. mmmodem
    2,732
    1,703
    Bay Area, CA
    The depreciation loss will be too great to return the car. You won't be able to get great fuel economy with the PiP over a regular Prius for your Saturday commute but it will still be better at 56 mpg versus 50 mpg not counting electricity. What you can so now is take advantage of the perks the PiP has over a regular Prius.
    1. $2500 federal rebate on your taxes
    2. $1500 CVRP rebate in the form of a check from California
    3. Solo occupancy in HOV lanes
    iPhone ? - now Free
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Thanks for replying can I please get some info for how to apply for the 1500$ the dealer doesn't have much knowledge I'm in California
    Thanks
    image.jpg I love the way it stands out
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
    Type in CVRP in google. The first result is what you want. I got a blue one too. I really think you made the right choice in the PiP. All it takes to convince you I think is one day in heavy traffic and you cruise through traffic in HOV lanes.
    iPhone ? - now Free
  15. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I had already put a deposit for a fiat 500e but I was always going to extremely anxious because the charge could possibly deplete after a couple of hills. Pip has a gas tank and I never get anxious about running out of charge and I had 2010 prius that I drove 180,000 miles until my son salvaged. Prius is just a altogether great car
  16. skbt
    skbt New Member
    I just filled up the gas tank for the first time two days ago. I drove 724 miles and filled it with 8.5 gallons (85 mpg overall). Of note, my daily commute is 9.5 miles roundtrip so usually the hybrid engine never turns on. I did take a few long weekend drives.
  17. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Did you do any actual research before purchasing the Plug-in Prius?
    If you did- you'd know the EV range is about 12mi- after that you're running on gas. On a 100 or 200mi trip- 12 EV miles will hardly contribute to your mpg figures.
  18. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Yes I did do some actual research and I was we'll aware that the pip gets 12-18 miles per full charge but I was expecting that once I had a full charge the car would only use 1 gallon of gas for the first 100 miles by using the larger battery in combination with the ice
  19. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    PiP was made to excel in short trips. I don't want to sound annoying but a liftback would've been a better financial choice than the PiP for long commutes. Then again you probably get better tax breaks, incinitives, and green cred with a plug-in. ;)
  20. ny_rob
    1,968
    813
    L.I.- NY
    Well- if the main battery gives you 12 EV miles- that means the other 88 miles (on your 100 mi trip) have to come from the ICE.
    I can't understand how you thought that you'd get 88mpg out of the PIP once the main battery was depleted? The PIP has the same engine as the std Prius- there is no logical reason to assume the PIP with a fully depleted main battery would get any better mpg than the standard Prius (mid 50's mpg in most cases).
    If you can keep to shorter trips (I get up to 110mpg on my 28 mi trip to work) - you will get amazing mpg results with the PIP- but with an EV ratio of 10% you're not getting any practical benefit out of the PIP.
    Phausto, Priusmpg and TheEnglishman like this.
