Oil change with ramps?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by spiff72, Sep 12, 2013.
  1. spiff72
    spiff72 Member
    184
    37
    West Michigan
    Just curious whether I would have sufficient access to change the oil on a prius using only ramps (no jackstands)? My main question areas woukd be whether the access door can be opened up fully and whether the filter can be accessed. I think my ramps are 8"?
    Thanks!
    Galaxy Note 2 - pardon the typos...
  2. Indy John
    Indy John Member
    75
    33
    Indianapolis
    My plastic/foam "Race Ramps" are 8" lift and are just enough to allow full opening of the access flap. A floor jack under the front jacking point (an added wood block may be required) and a pair of jack stands lets you go higher.
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Yes. The cover that you will need to move back is somewhat flexible, so you can bend it and fold away, opening the access to the filter and drain bolt.
    - Alex
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Yes, as stated above, you will need to bend the access door back in order to be able to clear the ground and get the access door out of your way. It is flexible enough that I just push up on the back of it (hinged part) and then bend the access door slightly to clear the ground.
    Once the access door is out of the way there is adequate room to complete the oil drain and oil filter removal and replacement. It is tight working quarters but it is adequate. A floor jack and jack stands would give you additional room but it is not necessary.
  5. El Dobro
    El Dobro A Member
    7,090
    3,270
    I always use ramps for changing the oil, but I prefer to remove the entire bottom cover. I like to make sure things are ok under the car. ;)
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    +1 I remove the entire bottom cover every other oil change. I change my oil every 5k miles.
  7. spiff72
    spiff72 Member
    184
    37
    West Michigan
    Thanks for the feedback, everyone... I changed my oil on Saturday without issue with my ramps.
    Two observations:
    1. I was able to use oil filter pliers on the filter cover.
    2. When I went to remove the oil plug, it was only finger tight. Yikes. I can't believe it wasn't leaking.
  8. Mide
    Mide Junior Member
    Yup I have those Rhino ramps and I can change the oil with no problems. I would agree with other posters that it is better to remove the whole plastic undercover. When I tried to just open the little square "door" for the oil area it ended up ripping off...bad design.
    Fostel likes this.
  9. Mendel Leisk
    41,863
    I've been having a similar issue with previous (non-Toyo) vehicle of ours, still in the family. I think the culprit is the new-fangled drain bolt washers, the kind with some sort of plasticized layer. Every time I re-install it I know it's torqued, and every time I go to remove it it's nearly free-turning.
    I think the plastic layer shrinks/contracts somehow. I miss the plain Jane flat aluminum washers, more dependable, easier to remove from the bolt and/or never stuck to the oil pan.
    Merkey likes this.
  10. spiff72
    spiff72 Member
    184
    37
    West Michigan
    Yeah - the same though occurred to me. When many plastics have a stress applied to them for a length of time they can "creep". It is actually a well know principle in engineering.
    I can't recall now if it was completely plastic, or it was an aluminum washer with plastic coating on each side.
  11. Merkey
    Merkey Active Member
    319
    291
    Birmingham, Michigan
    Noticed the same thing. Some oil around bolt so I re-torqued. I bet it is the washer material.
  12. hlunde
    hlunde Member
    419
    75
    Actually not creep (constant stress with strain increase) but relaxation (constant strain with stress reduction).
  13. Tande
    Tande Active Member
    550
    337
    Mich.
    With an oil/change/door that could have been designed by a 10 yr. old & the "Scary" engine "Hammering" on cold start/up......makes me wonder "What the he!! is going on over at Toyota!o_O .....
  14. Mendel Leisk
    41,863
    The Toyota Repair Manual says to take the whole cover off (and a couple more in the vicinity. LOL). That said, the flap seems purpose-built for oil changes. I used ours once, but never again, it didn't seem to like bending.
    Part of the issue: Toyota says NOTHING in the Owners Manual on the subject of basic maintenance like oil changes. My only other experience is Honda, they've invariably included oil change instruction in the Owners Manual.
  15. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    I agree. The flap is the right size and location for an oil change. If you can get the car up 10 inches, it works quite well.
    Toyota does not include oil change instructions because they want the dealer to service the car. The oil change is just a portion of the entire service.
  16. El Dobro
    El Dobro A Member
    7,090
    3,270
    The flap is for access to oil changes, but it falls off from use.
  17. Mendel Leisk
    41,863
    There's actually two hinges in the engine under panel. There's a larger, full width hinge, but it would require the car to be raise much higher than a typical ramps or floor jack lift.
    Funny, we've got an 06 civic hybrid with similar under panel. It's got a hinge as well, but the plastic on that panel is about 3 times the thickness, and you could flex the hinge 'till the cows come home, it's softer plastic, more durable. That said, it's almost unusable for DIY, requires a very high lift to swing it right down.
    Here's the second hinge on the Prius panel (highlighted in yellow):
    Fostel likes this.
  18. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I do not disagree that the oil drain cover could be better and heavier. I have folded mine back many times in 4 years and it is still in good shape with no signs of stress at the hinge.
    Thanks for pointing out the second hinge, I have never noticed this.
    Fostel likes this.
  19. Mike500
    Mike500 Senior Member
    2,593
    767
    Ramps work fine.... Here are photos of my first oil change, last year...
    Fostel likes this.
  20. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    Do you use any clips removal tool or just flathead? How many clips are there to remove the whole thing?
    Thanks.
