DETORIATED RUBBER ON HATCHBACK OPENER
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jackgrooms, Sep 11, 2013.
  1. jackgrooms
    jackgrooms Junior Member
    Sourh Carolina
    I read the post concerning replacing the hatchback switch and other fixes that had been posted. My 2009 Prius hatchback rubber was torn and deteriorating. I had a problem paying the price for a switch just to get the rubber. I bought a 1/8" sheet of neoprene with adhesive back. I removed the switch per instruction I found on the forum. I cleaned the switch with paint thinner. Then I cut the neoprene slightly bigger than the switch. I punched holes in the neoprene for the screws, then removed the backing and put it on the face of the switch and re-installed. It works fine. Since I just did this I cannot tell if it is a permanent fix or not--I hope so.
  2. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    Got any pics of your finished product?
  3. Poosey
    Poosey Junior Member
    SW Florida
    Thx, mine melted here in SW Florida. lol
