Seat Heaters
Discussion in 'Prius v Main Forum' started by harold, Jul 13, 2013.
  1. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    Test drove the v yesterday. Heat from the Seat heaters was near non existant. They are important to me for theraputic reasons. Anyone with seat heaters have an issue with them or find them luke warm heaters?
    JMD likes this.
  2. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Hasn't been an issue here. They toast buns and thighs...
  3. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    From your location you are driving in southern Florida and in summer? You can't expect seat heaters to toast you in the summer. Come up north and try them when it is minus 10--they will heat your up then.
  4. parnami
    parnami Member
    227
    48
    .Lancaster, PA (Amish Country) :)
    I turned mine on last week, hoping for relief for an aching back. It was a hot day. After a couple of minutes, I realized there was no heat coming from the seats. They worked fine in winter. I'm wondering if, somehow, they are linked into the hvac controls and work only when temps show it to be practical??
  5. CLUBGUY
    CLUBGUY Member
    293
    Cincinnati
    They are not as warm as the ones in our "08 Town and Country; they were very warm on the high setting....
  6. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    Living in Florida , we will always have the a/c on. So does that mean seat heaters will never work ?
    I didn't see any setting adjustment, just on and off? Am I missing something?
  7. CLUBGUY
    CLUBGUY Member
    293
    Cincinnati
    Seat heaters operate independent of the AC/Heater controls....
  8. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    Anyone in a hot weather state have hot seat heaters?
  9. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    They work great. In the winter morning commute I don't put the car heat on, just the seat heater and I drink a hot coffee in a travel mug. Than again I'm in So Cal and winter temp is above freezing almost always.
  10. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    When we test drove yesterday , in south florida , we put the seat heaters on and neither my wife or I found them better than luke warm at best.
  11. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    The heating elements cycle on and off automatically - no adjustments.
  12. Air_Boss
    4,218
    1,188
    New Yawk
    They are WAY toastier than our '05 CR-V SE...
    But not as hot as sitting on the exhaust pipe of the '68 2000 after it warms up...
  13. john1701a
    john1701a Prius Guru
    12,819
    5,303
    58
    They felt great to me last winter, here in Minnesota when the temperature dropped below 0°F.
  14. JMD
    3,779
    1,282
    Harold for the sake of your sanity I would test drive another Prius ( Same model just another car Vin #) and test the seat warmers. The car does come with a bumper to bumper warranty but make sure you get the one that the seat warmers work to your satisfaction. Toyota goes through a extensive QC process but make sure you get what you want and everything works.
    I recall test driving a Prius and not the one I purchased and the Sirius did not work when the sales person demoed the car. He said it is probably not activated we can fix that. The sales guy said that's not that awful I had one with a dead battery on the lot, he said it was not started in awhile. He talked me out of the sale. PC talked me back into it.
    Buying a car is a big decision. Don't be forced into anything. Test everything. If the car is not for you move on to something else.
    I can say from experience the Prius is a great car. It is economical, comfortable, safe and reliable. Than again my previous car was a BMW which was a Money Pit on maintenance & repairs, gasoline took Premium and the MPG was horable. The seats were very comfortable and the seat warmers and navigation were exceptional. However that car was a waste of money.
    archiveman2977 likes this.
  15. archiveman2977
    archiveman2977 archiveman2977
    49
    Central Texas near Austin
    2013 Prius v wagon
    We tried the seat heaters when it was 95 outside, 75 inside w-AC--we had to turn them off--very warm.
    9-11-13
    JMD likes this.
  16. GerryL
    GerryL Master Model Railroader
    170
    Minneapolis, MN
    Mine work great (I had the dealer add them to my v Three). In fact, there are times, even in winter in Minnesota, when I've had to turn them from High to Low because they were TOO hot.
  17. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    I had a similar concern before buying my car a few weeks back (not a v though.)
    I found that the liftback that the seat heaters are not only quite hot, but also that they reach hot very quickly.
    The v should have a low and high setting based on what people were saying in the thread I started. Make sure you select the high setting.
    Definitely try another test drive and if the temp is so hot there I would be sure to get the AC cranking, put it down on 68, and then once it's frosty inside turn the seat heaters on and it should be good.
  18. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    The thread you started must have been in the Gen III forum. I know my max trim 2012 Prius v (wagon) only has on/off seat herter buttons. Harold doesn't have it on his 2013 Prius v either.
    My last observation about my seat warmers is that I notice significantly more heat when the ICE is running at moderate to high RPM. It is almost like having a High/Low setting. High when ICE is producing extra power, and low when you are driving economically. I just had the thought that you might be able to select the High setting by putting the vehicle in Power mode. I'll have to check that out. I hope toyota spends (or explains) a little more on the seat heater controller because I remember it getting too hot (fast) when driving highway speeds. But that is just a good reminder that everything is heated up properly and to use the button and turn it off. I use it to offset setting the cabin heat lower or off. All in all, I happy with this option with the caveat that there is more than usual room for improvement.
  19. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I'm still confused how the seat heaters work. Seems to me from using them last winter in average -15 celsius they come on really hot(but not unbearable) then cool down a bit then heat up again, then cool, repeat..
    used them for the first time this season yesterday morning driving to work. it was a chilly +14c, so instead of running the heater, just turned on the butt warmer, worked great. when I got to work i forgot to turn it off. Got in at the end of the day and it was +28c outside. Driving home and the seat heaters were on the whole way, didn't even notice really, the ac was working good haha. So it seems to me if it is really hot out your just not going to notice them as you already feel warmer than you would on a cold winters day, and if those seats are softex they will already be preheated naturally sitting in direct sunlight, and, on the other hand very cold to the touch on a cool winters day.
  20. john1701a
    12,819
    5,303
    58
    My 2010 Prius cycled like that.
    My 2012 Prius PHV doesn't. Instead, it has a Hi & Lo setting, which are both continuous.
