Paint bubbled up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by echeng66, Sep 14, 2013.
  1. echeng66
    echeng66 Junior Member
    Michigan
    I have a small area in the hood (2008) with paint bubbled up. (See picture.) I did a search and found one thread on it. So I gained some understanding about this. I have extended warranty till 100,000 miles. Do you think they will cover this?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,072
    552
    Tucson, AZ
    2021 Prius
    I thought the hood and various other pieces were aluminum. That wouldn't be rust then.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The hood is aluminium unless the car has had repairs replacing the hood with an aftermarket unit. These are often steel. Aluminium however does corrode particularly in the presents of salt.
    John (Britprius)
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Almost identical post of yours farther down on the forum list. And the remedy. Here:
    Front end corrosion | PriusChat
    Lack of paint maintenance (not waxing) causes acid to etch pinhole in paint and water-rust gets under the paint and bubbles paint. Because of this the extended warranty coverage will be a hardsell
    imho.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Now you've gone and made me wonder if my Prius had ever had any serious panels replaced (since I got it second hand). I just did a quick test with a fridge magnet. Magnet stuck straight away to all four doors and front and rear quarter panels. Then I checked the hood and the rear hatch and sure enough the magnet slide straight off without any force at all. So yep, it checks out ok. :)
    Britprius likes this.
  6. GMAccord
    GMAccord Junior Member
    I have the same bubbling problem in my 2009. I am the first owner, very well maintained car with not even swirl marks in the paint. Does not seem to be classic rust problem. It seems as if the paint adhesion itself has some issues. The bubbles are in a area where both the front and back of the hood visually looks perfect (meaning no break in the paint surface).
  7. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Aluminum is especially hard to prime properly.
  8. echeng66
    Michigan
    Thanks for all the replies. There was no damage to the hood prior to this. Just saw it the other day. I do not know when it happened. It is a 2008 with over 90,000 miles. I will check with the dealer to see whether it is covered under extended warranty. If not, it is not a super big deal. I guess cosmetic is less of an issue as this point.
    Thanks.
  9. pcdave
    pcdave Junior Member
    48
    Scotland
