I did a test drive on the CMax
Discussion in 'Ford/Lincoln Hybrids and EVs' started by jhinsc, Apr 12, 2013.
  1. spitinuri
    spitinuri Member
    317
    I would not dispute your rationale. It is a perfect car for you.
  2. spitinuri
    spitinuri Member
    317
    In a test drive at highway speeds I was able to get 44mpg. I would compare it most generously to my first drive in a Prius.
  3. afob3
    afob3 Member
    124
    40
    TN
    The one thing I didn't like about the C-max was the turning radius. It was like navigating an aircraft carrier.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    My wife test drove the C-Max while I rode in it. One shorter drive, one longer (45-60 min) drive.
    - Only got a bit under 40mpg.
    - Found the gas pedal over-responsive, at least at lower speeds. (But she wasn't unhappy and figured she'd get used to it).
    - Liked the ride.
    - Not sure on comfort since it was a day with a lot of driving.
    She liked the car. If she/we tested it again I'd want to try an Energi since it could cover her commute.
    I didn't like the car, because I judge cars by fuel economy and all-electric range. :p
  5. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    I drove both the Hybrid and Energi C-Max models. The hybrid only returned 38 mpg.
    The Energi returned 54 mpg on a 4 hour round trip to lunch in Carmel by the Sea. Needless
    to say, I purchased the Energi and love it. I have no problem beating my Prius C mpg numbers
    in hybrid mode, not using the EV range. Using the EV range, I get about 28 miles per charge.
    My MPGe mileage is currently at 69 mpge and rising :cool: 20130825_112342.jpg
