ClipperCreek Launches LCS-25P: World’s Smallest Cord and Plug Connected 20 Amp Level 2 Charger
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, Sep 16, 2013.
  1. Francos
    Francos Member
    118
  2. Nathen
    Nathen New Member
    2013 Prius Plug-in
    Let me know when the World's Cheapest Cord is launched, I still don't understand why these things are going for $500+
    JimPHL likes this.
  3. bisco
    52,070
    how many people need a portable 240v evse? are there that many 240v outlets around?
  4. Francos
    Francos Member
    118
    No installation cost if you already have a plug.
    Easier to send it to service if something wrong.
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    It's a good alternative to the OEM EVSE if it fails... and it's already upgraded for 220/240v operation.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Depends where you live...
  7. hill
    8,832
    I duno . . . how many RV parks are around. That's just a fraction of a start as there are lots of other entities that can give you 240v. Here's local state federal camp grounds of which most have 240v for RV folks (doesn't include private camp grounds, which would more than tripple the quantity):
    cwerdna and inventor00 like this.
  8. bisco
    52,070
    can you use these outlets without staying there?
  9. bisco
    52,070
    good point, mine is also plug and play. what is involved with the 'installation' of a non portable 240v evse if the 240v outlet is already there?
  10. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    This does not support 110, it is 240 only.
    EVSE upgrade or OpenEVSE is the way to go still.
    cwerdna likes this.
  11. bisco
    52,070
    exactly.
  12. Francos
    Francos Member
    118
    So which plug is more common? NEMA 14-30, or L6-30?
  13. bisco
    52,070
    L6-30 i believe.
  14. hill
    8,832
    many will - if you're truly interested just call ahead. Some will charge you a token amount while others will let you charge for free. RV parks helped Tony Williams become the first Leaf to travel from Baja California /San Diego border all the way to Canadian border.
  15. bisco
    52,070
    that's pretty cool! would definitely make the evse upgrade worthwhile.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    What is the Max amperage the PIP can handle again?
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    If you are speaking of charging amperage then my (230V) manual says:
    "Connect to an AC 220V-240V socket with Residual Current Circuit Breaker and supplied by a circuit breaker"
    and
    "Use of an individual circuit provided with at least 13A is strongly recommended"
    and
    "The charging operation is designed to operate at 10A continuously for the charging duration (about 1.5 hours)". My experience: about 9A from the wall (calculated from energy used, time and voltage).
    F8L likes this.
  18. Francos
    Francos Member
    118
    I just found out that I have a 240V line that goes by my garage to my sun-room (wall heater). This makes my project much easier. I rarely use the heater. I am thinking to cut the cable from my garage and install a switch, maybe a toggle switch to let me easily direct where the current goes to avoid the concurrent use of the two devices (EVSE and heater).
    I could not find the toggle switch for my purpose with the 30AMP rating. help is much appreciated!
  19. Francos
    Francos Member
    118
    To clarify, the toggle switch will split the 240V cables into two, one goes to heater and the other to Lp-6R (for EVSE). The switch will restrict the current to one line only to avoid the concurrent use.
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks!
    I was trying to find out if the PIP would benefit from an EVSE that runs at a higher amperage. The OE EVSE runs at 12amp max. I had to think about that when I upgraded my EVSE for my Volt. The Voltec unit is 13amp and the PIP unit is 12a. I decided on the PIP unit because it is a quality piece and the Voltec was considered junk. Until I found out the 2013 Voltec units are made by Clipper Creek which = great. LOL
