Best tires for MPG
Discussion in 'Gen 3 Prius Main Forum' started by MScx6, Dec 30, 2012.
  1. MScx6
    MScx6 New Member
    I'm in need of a new set of tires after 40k miles. I have some uneven wear on one tire. Annoying, but I need some new tires so I want the best possible MPG. Has anyone found a good tire that you would recommend?
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    #1 Michelin Energy Saver A/S 195/65/15 (T)
    They are sometimes hard to order but they are worth it.
  3. harper42
    harper42 Member
    226
    Winter: Michelin X Ice. Car drives in snow like a little snow machine. Other: Michelin Hydroedge. I was in a flood in Columbus, IN and drove through water deeper than one should ever attempt.... but there was water every direction!
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    But he asked for the the tire that offers the best mpg. :)
    Daddyjeph likes this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    It probably goes without saying but after you have made your mind which tires you are going to purchase, make sure you have your car aligned. You can seriously deminish the MPG with the front tires out of alignment. Excessive tow-in or tow out, especially. What I am trying to say is, take it to someone that knows what they are doing. Insist on optimum settings.
    F8L likes this.
  6. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    You already have the best advice, from F8L, go with it!
    duanerw and Daddyjeph like this.
  7. ryano7700
    ryano7700 Junior Member
    29
    KY
    F8L,what is your opinion for the best mileage 17" tires? The ecopia's you have? If those would get me 60.6 like you, I would change right now.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    The Ecopia EP422 is the next best mpg tire in that size. I think the OE Toyo Proxes A20 offers better fuel efficiency but they are very expensive and a pretty crummy tire overall. So the EP422 or Continental PureContact is the next best thing economically.
    My 60mpg fuelly is based on my 15" Energy Saver A/S tires. When I switched to 17s I stopped updating Fuelly. I created a second Fuelly for 17s so I could better track the impact. I'm now back on 15s but I haven't updated anything yet. I have a stack of gas receipts in my center console. lol
  9. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I have been very happy with michelin tires, so I will look for them when mine need replacement. I am intrested how much difference in rolling resistance between the michelin defender and the energy saver. because these tires have been great on several cars for me.
    how much mpg do you think would be the difference?:rolleyes:
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    I think the difference between the Defender and Energy Saver A/S is 3+mpg in favor of the Energy Saver A/S. The Defender should last longer though so it almost evens out in the long run.
    xraydoug likes this.
  11. xraydoug
    571
    176
    Roseburg, Oregon
    Thanks for your opinion. I guess I need to look at the cost of both ways. (y)
  12. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye and make sure they have the tires you want in a size that fits your car. ;)
    If you don't mind lower mpg numbers then the Defender is a great tire which in the end won't cost a whole lot more than the Energy Saver PLUS should you ever have to replace a single tire due to a blowout, the Defender is MUCH easier to find quickly.
  13. ETP
    2,803
    1,170
    Auburdale FL
    I am getting 59-62.3 MPG on factory OEM MIJ tires on my two driving to work. On a trip it goes down due to weight and speed to around 52-56 If one tire is wore out get an alignment as suggested. I also run 40-42 PSI. If you are not worried about the condition of the other tires consider buying two MIJ OEMs at Tirerack.com and put the two best old ones on the back.
    I was wrong! Don't do that! Put the best ones on the back.
    Maximum MPG for me in a hot climate. If you live where there is snow and ice you have safety issues to consider and that may be more important than MPG.
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    ONLY if you are going into summer (dry season) and the tires are not very worn. Otherwise the new tires (tires with the most tread depth) should go on the rear of the car.
  15. GBC_Texas_Prius
    218
    gbc texas
    If you follow the advice that the tires with the best tread should always go on the back, you would never rotate your tires. I've done it both ways. Never rotate, buy 2 new, put the new on the back. Rotate and swap all 4 at the same time. If you rotate, there will be times that the front have better tread than the back.
  16. zander
    zander Junior Member
    46
    connecticut
    Michelin Defenders
  17. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    im confused. Always thought that best tread should be on the front tires, since it is doing the work.
  18. ETP
    2,803
    1,170
    Auburdale FL
    A matter of opinion as I put the best on the front since it is front wheel drive and under high pressure. But I understand why people put the worst on the front to wear them out quicker. I just don't do that any more IMHO. To each his own.
    I was wrong put the best ones in the back.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    Nope. :)
    It has nothing to do with work. It has everything to do with traction in wet conditions and how the weight transfers when braking.
    More reading:
    Tire Tech Information - Where to Install New Pairs of Tires?
    Robert Holt and retired4999 like this.
  20. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    Here is a link to the Tire Rack LRR (low rolling resistance) tire test. This test is a little dated (2009) as several other tire makers have now introduced LRR tires. When you do a tire search for your size on Tire Rack, look at the bottom left column and you can select "only LRR tires", or just include/exclude LRR tires.
    Some folks do not like LRR tires because of the poor wet as well as poor braking performance.
    Tire Test Results : When Round and Black Becomes Lean and Green
    Robert Holt likes this.
