How to use 2005 aux input?
Discussion in 'Gen 2 Prius Audio and Electronics' started by aciel, Sep 9, 2013.
  1. aciel
    aciel New Member
    Hey guys, I just bought a 2005 prius. The audio system is the base version ( Not even the JBL version) with no navigation. At the bottom of my dash board there is a custom fit aux input with an on off switch next to it.
    I cannot figure out how to use it with my Android phone. On the screen UI there is nothing to suggest an alternative source. I checked to see if I could select a different cd input but only the main cd option shows up.
    The car also has what looks like a volume control fitted next to the dim / brightness controls on the dashboard. It doesn't seem to do anything and I suspect it is somehow connected to the AUX port.
    Thanks for any ideas you may have.
  2. Tor Morten Jensen
    Tor Morten Jensen New Member
    Steinkjer
    Have you tried turning your radio to AM/Sat? That may help.
  3. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    It sounds like someone has gone in and added a jack to an existing audio line. It might be with the CD or with the radio. Do you have a cassette player? It might work on that input, perhaps with a blank tape. Maybe on the radio with a blank (FM) station tuned in (it may mute static automatically)? Hard to say without seeing it but it does not sound like it is original to the car.
