Wheel Bearing Replacement NHP10R
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ghwong, Sep 23, 2013.
  1. ghwong
    ghwong Junior Member
    32
    Singapore
    Anyone gotten their wheel bearing changed?
    Was told by my service advisor the bearing are all worn out 50000km/31000miles servicing.
    Was curious how come so fast need replacement...
    52,286
    what??? are the symptoms?
  3. ghwong
    32
    Singapore
    when driving the cabin sound like plane.. haha.. the rest is quite subtle..
  4. bisco
    52,286
    did you go through any flooded areas? i'm not sure what would cause all the bearings to fail, defective maybe?
  5. ghwong
    32
    Singapore
    nope.. my place here rain often but not flooding..
    either defective or my wheel not properly balance previously (i guess)
  6. bisco
    52,286
    i think you would have noticed if they were unbalanced enough to damage the bearings. is it covered under warranty?
  7. ghwong
    32
    Singapore
    here in Singapore our Prius C is covered with 5 years warranty.
    So the bearing is free for replacement.. was just told by my service advisor again that this parts is covered. Lucky me :)
  8. bisco
    52,286
    that's good news. does he think they are defective?
  9. ghwong
    32
    Singapore
    yup.. they check and they told me it was defective and worn out
  10. bisco
    52,286
    most unusual, all the best with the new ones!(y)
  11. Stevie
    Stevie Junior Member
    95
    22
    Melbourne,Victoria,Australia
    see if you can get some pics of the old ones
  12. ghwong
    32
    Singapore
    Here in Singapore, they didnt allow us to go to the service area.. i doubt i will be able to get the pics.. will try to ask and see if able to.
  13. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Bearings can be worn out due to extremely rough roads or by high speed turning such as taking a 35 mph off ramp at around 50.
  14. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Dang. I'd better quit that, then...
    I always ask for my worn/broken parts back when they write up my ticket to start work. You may want to call them or drop by to ensure they know you want your old parts back.
  15. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Parts replaced under warranty are the property of Toyota. They are no longer your parts as they have given you new ones in return. They may want them returned for inspection or as proof that they have been changed.
    John (Britprius)
  16. Mr Incredible
    955
    506
    Neb
    Tks.
    Its been a long time since Ive had anything under warranty AND had parts replacement.
  17. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    Weird that you need bearings at 31k. I think they are not worn out. My Prius sounds like a plane inside too. Since I changed my wheels , tires and struts to make it handle better on the freeway it has only gotten louder. Now it is like riding in a propeller plane.
    Turn off signatures in Tapatalk Tapatalk
  18. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    oops, gotta remind myself not to race minivans on the on and off ramps from now on.
    :eek:
    ztanos likes this.
