Lo Beam out on right side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PristinePrius, Sep 25, 2013.
  1. PristinePrius
    PristinePrius Junior Member
    37
    Inland Empire, Cali
    So, I don't know squat about cars, but I'm trying to learn. A couple months ago our 2004 Prius' right (passenger) light went out. The driver's side works fine as well as BOTH the HI beams. I checked according to priuschat forums about the fuses and they seemed to look fine, not blown or broken. I read somewhere about the 40A amp, but I can't find where it should be. Any help?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    You probably need to replace the headlight bulb. I suggest you check the forum for instructions on replacing it.
  3. Mendel Leisk
    41,401
    Assuming it is a 2004 (you're posting in Prius v forum), it's likely just a dead bulb. It'd be worthwhile to replace both, or at least purchase 2 bulbs, have them on hand.
    Hopefully not to difficult to DIY....
    Our 3rd gen has the LED lights, and the Owners Manual simply says: bring it in to the dealership.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  5. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    sound like it's the bulb to me. swap bulbs to confirm.
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    On page 305, it instructs you to turn the cover counter-clockwise. I fought with mine for almost an hour exhausting options and myself. In the end, mine popped off without twisting. I just used the biggest flat-head screwdriver I own and gently pried the cover off. That took only a couple seconds. When I examined the cover, there were no threads.
    Just my 2 cents.
  7. PristinePrius
    37
    Inland Empire, Cali
    Are the prius Lo & High beam bulb one in the same? Why would the hi beam work but not the low light? I checked around for several days and it seems like alot of people had my same question. I read somewhere about taking a look at the 40A fuse, but I can't seem to find it still.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  9. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    On the Gen II Prius with Halogen the left and right low and high beams are each on a separate fuse. Right hand low beam is a 10amp fuse # 26 in the fuse box under the hood. The white plastic fuse gripper/holder is located in a slot on the right side of the box. This helps you remove the old fuse and insert the new. I've attached the pages from the owners manual with all the fuse numbers and sizes.
  10. PristinePrius
    37
    Inland Empire, Cali
    Thanks JimboPalmer for the filament lesson. I didn't know that, but it makes sense. But while under the hood, I re-checked my fuses and I noticed my 10A fuse is missing. When I checked earlier, I could have sworn all four were there, then the boyfriend checked and said he doesn't remember seeing it there. Anywho, I'm about to purchase a new bulb and also a small pack of fuses. Is it just safe to buy both now or just buy the fuse and see if that's my problem? Thanks in advance!
  11. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Just start with the fuse. Then if the lamp is still bad, you can buy the lamps. Any time you replace your automotive lamps, if it is a paired set, that is both left and right come on when you turn them on, you should replace both left and right at the same time, even if only one burned out. The other is not far behind. We have all seen cars on the highway with one light brighter than the other. That's why. They only replaced one. Most of the lamps come in a two-pack anyway.
  12. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I concur with the above statement. I have seen many vehicles in the past. It always seems to workout that one headlight goes out, the other is not far behind it. I have also seen two of them go out at once, however that was a one time thing. Besides all of that, if you were to change only the one that is out, you will then have a bright bulb and a dim one. Unless you are using the "ultra bright" type bulbs (non oem), you generally only have to change the bulbs once during the lifetime of the car. Note, I did say generally. YMMV
    Hope this helps.
  13. PristinePrius
    37
    Inland Empire, Cali
    Thanks everyone who helped. Replaced the fuse AND lightbulb because there was something wrong with the coil had broken off. Unfortunately, now I have a "check engine: light that loves to keep turning on then shutting off...
