anybody have same problem?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by freeHUG, Sep 25, 2013.
  1. freeHUG
    freeHUG Junior Member
    :cautious:
    Hi everybody,
    Does anybody have problem for you Prius have look like orange peel on the engine and rust ?
    thanks
      File size:
      109.7 KB
      559
      File size:
      111.2 KB
      490
      File size:
      111.4 KB
      400
  2. JDB
    JDB Junior Member
    24
    I have 2013 Prius Two, noticed the same thing on mine. In similar areas as well. I'd be curious to learn if this is an issue.
    On another note, I've heard there are rust preventers to spray to protect engine from rust. Anyone have experience with this?
  3. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    You might want to edit your subject line so that it's more descriptive of an issue about rust for those searching, etc.
    Les_PL likes this.
  4. mediahound
    903
    155
    PS, I just looked at mine (brand new Prius, only a few weeks old) and do have a bit of orange rust on that piece. It's probably normal.
    The other piece is also sort of crinkly and that is probably also normal.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Not orange peel its casting slag. All cars have it. Its not a Lamborghini. If that minor rust bothers you never look under the front end.
    And the spray mentioned is called CSP. Corrosion Stop Protector.
    Its the best product ever. Once a year the underside of my cars get it especially the front end. It prevents rust and eliminates front end squeaks, rattles, & groans. Anything that moves gets it. All the door hinges and locks etc.
    Found only at Home Depot. This stuff:
    Search Results for csp spray at The Home Depot
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The inability to write a descriptive title? Yes, that is common to many PriusChatters.
    Your picture two is just rough aluminum
  7. mediahound
    903
    155
    Does that stuff weaken the metal or anything like that?
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
  9. Former Member 68813
    3,524
    983
    US
  10. hlunde
    hlunde Member
    419
    75
    This is why cars like Audi have a large number of trim panels in the engine compartment creating a styled appearance and obstructing the view of the engine. They assume correctly that customers make purchase decisions based on cosmetic appearance of the machinery.
