Fuel Economy: Prius vs Airplane
Discussion in 'Gen 3 Prius Fuel Economy' started by Jonny Zero, Sep 28, 2013.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    According to this, if you carry one passenger (100 MPG per seat), the Prius is greener than the greenest airline. If the Prius is fully loaded, 250 MPG per seat, there is no comparison.:)
  2. walter Lee
    1,126
    376
    Maryland
    LOL. What about a piper cub or a Cessna? Or a Helicopter?
    A jetpack can only go for about 3 to 5 minutes before you run out of fuel .... :-P
    I wonder how many pigeons or helium balloons it would take to lift up 200 pounds? :)
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Mythbusters used over 3000 helium balloons to lift a 40 lb child.
  4. bwilson4web
    16,353
    Then there is the block-to-block time:
    • 20-25 minutes to reach the airport
    • 30-45 minutes in-processing and boarding
    • 1-2 hour first hop
    • 30-60 minutes transfer
    • 1-2 hours final hop
    • 20 minutes to get luggage and rental
    • 20-25 minutes to leave airport and reach destination
    There is a break-even point where flying takes longer than just driving to the destination. It of course varies but somewhere close to 400 miles becomes the threshold. Shorter, one might as well just drive to the destination. Longer, the plane wins.
    FrankTiger and telmo744 like this.
  5. El Dobro
    El Dobro A Member
    7,093
    3,271
    Did they ever get the kid back? :p
  6. Feri
    Feri Active Member
    761
    144
    Lots of safety lines. She was a cute little thing.:)
  7. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Notice how they give 'seat miles' for planes but not for cars...
    Also the energy content of jet fuel is close to that of diesel, not E-10 gasoline.
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    2 hops for 400 miles.... I don't think so. Although 400 miles is about right for drive or fly.
  9. fuzzy1
    10,602
    You didn't include:
    • 20-45 minutes TSA security screening, including wait line
    • tbd -- safety margin to ensure 2- to 3-sigma probability of not missing the flight
  10. fuzzy1
    10,602
    That is very well disclosed in the caption, far better than most other news factoids we get.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    If there are no two hour delay's. :D
  12. Former Member 68813
    3,524
    983
    US
    I thought you should be at the airport 2 hrs before the flight?
    It all depends on connection, distance from airport and such. Once I has such a tiring 800 miles flight (2 legs), that i would be much easier to drive.
  13. walter Lee
    1,126
    376
    Maryland
    That's significantly more balloons than in the french film short "The Red Balloon"(1956) ....o_O
    My balloon fantasy has been busted. :cry:
  14. Corwyn
    2,171
    659
    Maine
    True enough on the latter phrase.
    "Mileage for autos is based on full vehicle, not seats"
    This is a very open to misinterpretation. "whole vehicle" would have been unambiguous, "full vehicle" gives the impression that they assumed full capacity of passengers, rather than the opposite, no passengers.
  15. qdllc
    qdllc Senior Member
    1,377
    400
    Misleading math.
    Big vehicles (buses, trains, planes, etc.) operate under an economy of scale. You might get 9 MPG, but if you're moving thousands of pounds or dozens of people, you're overall more efficient than something getting 100 MPG but only able to haul a few hundred pounds or a couple of people.
  16. bwilson4web
    16,353
    Private vehicles also operate on the owner's schedule and carry more and varied luggage.
  17. Former Member 68813
    3,524
    983
    US
    How is it misleading if you calculate MPG per passenger?
    The math is either correct or incorrect, it's not like you spin math equation.
  18. Feri
    Feri Active Member
    761
    144
    Sorry Walter!:(
  19. qdllc
    qdllc Senior Member
    1,377
    400
    Maybe I worded poorly.
    When judging MPG, you have to consider many factors. A plane or train or bus looks less fuel efficient, but when in it's element, it may be more fuel efficient than the most fuel-sipping car.
    Just like a Prius gets it's best MPG with no cargo and just the driver and a full-size pickup truck isn't a bad deal when it's hauling passengers and cargo.
    I was concerned about how good my MPG would be when I got the Prius because I couldn't test drive in my area to see how well it did in light of my daily driving. What one person gets and another person gets (and what they produce in a lab for the government) can all be different things.
  20. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Recall my Cessna 150 was about 4.5 gallons per hour at a 90 mph economy cruise, so a little less than 20 mpg for pilot only and less than 40 mpg for pilot plus 1 passenger (max capacity). BUT, straight line distance for aircraft was usually 20% les than highway distance for cars. Any way I compute it, the Cessna was less efficient than Prius with same number of pilot and passengers but was also quicker on the long cross country flights.
    Other small piston aircraft were typically less efficient than the Cessna 150, and helicopters were WAY less efficient, so the Prius with 2 people is more efficient than traditional aircraft. Electric aircraft may be even more efficient, but they are quite new and maybe should be compared to the Leaf and Tesla rather than the Prius.
