Why is driving with windows down such a pain?
Discussion in 'Gen 3 Prius Main Forum' started by mediahound, Sep 17, 2013.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Is it just me or does the Prius with window(s) down put in a huge blast of air?
    I've never had a car before where rolling the window down put in so much gale force wind into the car. I used to be able to drive with windows down (not on freeway and sometimes even on freeways) quite comfortably but now it is just too much wind blowing into the car.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I would guess that to get the best aerodynamics, they optimized for the most aerodynamic shape. What happens in less aerodynamic conditions fell by the wayside.
  3. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    I find that just using the rear windows works well.
    iPad ? HD
  4. mediahound
    903
    155
    Thanks, I'll give that a try.
  5. Former Member 68813
    3,524
    983
    US
    I do it all the time. Up to 50 MPH is fine. Above, it's a bit too much noise.
    If it's too much wind for you, you can only open right side only front and rear or diagonal pattern. Rear ones only don't work, huge noise!
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Nothing to do with aerodynamics. Well, it may be related but it's not "because". My FJ Cruiser is much worse, and it is CERTAINLY NOT aerodynamic!
    Like most vehicles, if you open the rear windows you get a low frequency oscillation, a "booming". If you have a sunroof try opening it up just so it tips open, not slides, then only open the inside cover an inch or so. Then crack the side windows open an inch or so. If that is not enough you can turn on the fan, but after you turn it on you may have to turn off A/C. Seems sometimes it turns on when you turn on the fan. :)
    On the highway it's supposed to be more efficient to use A/C with the windows closed. I have proven this in the GII but haven't tested the GIII yet. I suspect it's the same.
  7. fed123
    fed123 Member
    120
    New Jersey
    2024 Prius Prime
    Much better than with my last non-Prius, the Volkswagen Jetta.
  8. ETP
    2,804
    1,170
    Auburdale FL
    I crack the driver one/about an inch. and roll down the passenger about 20-40%. It is difficult to get a good airflow and no wind noise. With the radio on the driver window stays up. LOL At slower speeds I get better MPG with windows down and AC off. Soon it will cool off and can enjoy all the fresh cool air.
    59-62.5
  9. hlunde
    hlunde Member
    419
    75
    Quite some time ago, auto manufactures apparently decided that air conditioning was so prevalent (at least in the US), that they removed the small triangular front vent windows. These small windows worked really well.
    Ever since, your only real option is a tilt up sunroof.
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The Prius has the small triangular front windows, they just don't vent. ;)
    hlunde likes this.
  11. jgilliam1955
    368
    102
    Williamsburg, Virginia
    You are right. My Jetta was the same way.
  12. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Yesterday on the highway I was messing around with the free iPhone app Decibel_10th:
    With windows closed: bouncing between 70-75 dB ( "average inside car" and "loud singing")
    With windows open slightly louder: bouncing between 75-78 dB ( "loud singing" and "average car")
  13. nkx1
    nkx1 Junior Member
    Buena Park, CA
    I agree, the wind noise is quite loud in the Prius, even with varying combinations of windows up/down. The best I've come up with at speeds greater than 40mph or so is rolling the front and rear windows down about 1.5 inches. Of course, this doesn't provide a ton of air flow, but does allow for fresh air to enter.
    I miss my Corvette in this regard (and many others except fuel economy of about 21 mpg). I used to be able to drive at 65+ mph with comparatively little wind noise with the windows down half way. The Prius is MUCH louder. From this experience, given the commensurate drag coefficient of the cars (claimed 0.29 for a 2004 Corvette vs claimed 0.25 for a 2010 Prius), the aerodynamic efficiency of the car probably has little to do with how much noise is generated with the windows down.
  14. ataylor2
    ataylor2 Member
    122
    East San Francisco Bay Area, CA
    I thought I was just getting old. I was thinking the other day, that it was a very long time in my driving career I drove cars without A/C and even longer when I was a kid. I always had the windows down but never remembered getting blasted like now. I was chalking it up to getting soft from having newer cars.
  15. Former Member 68813
    3,524
    983
    US
    What speed and were all windows down completely?
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I measured at 65 MPH speed, did not see much impact of speed down to at least 45 MPH.
    As far as window, probably just passenger side where I was sitting.
    Note that I did the measurements before I saw the thread, so I was not trying to answer the specific question.
  17. mastergunnera8
    mastergunnera8 Junior Member
    93
  18. Bingee
    Bingee Member
    210
    62
    Michigan
    That's why I enjoy spoiling myself with A/C
  19. jgilliam1955
    368
    102
    When I was younger very few people could afford AC. I remember those wonderful hot sweaty says...LOVE MY AC!
    SCH-I535 ? 2
  20. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Rode in a friends 60 something dodge dart a few years ago. Those little triangular windows that fold out were awesome!
    That said i've tried driving around with windows down sometimes in the summer but where I live there is alot of traffic around you all the time so the noise and smell from surrounding vehicles is very unpleasant. Usually windows up and auto ac on all time time now. Quite often have to use recirc mode as well when behind a vehicle more than 10 years old thats belching out blue smoke or has a leaky exhaust/fuel system. :confused: Thank goodness for the local aircare program or i think vehicles with broken or no emissions controls would be much more common.
