Engine covers installed.
Discussion in 'Prius v Accessories and Modifications' started by ImeanGreen, Jun 16, 2013.
  1. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    the covers really finish off the engine bay
  2. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Mine with adjustable hood lift and more. ;)
    Cristino and ImeanGreen like this.
  3. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Like the idea of the synergy drive logo covering the hole.
  4. Andress8100
    Andress8100 New Member
    Really done a nice job there man. The display you present for us is inspiring and very professional. No doubt that really gives the engine bay a finished look. Sure this idea will be referenced long into the future. Like it.
    Wheelchair Accessibility
  5. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Thanks for the kind words. At first I added the chrome emblem as seen below but it seemed too flashy so later I put the carbon fiber emblem in stead but the silicone glue wouldn't hold. :oops:
    Hood damper (lift, prop) | PriusChat
    As for the hood lift, you can follow it above if interested.
    #25 tanasit, Oct 1, 2013
  6. thx123
    thx123 Junior Member
    CA, USA
    2014 Prius Plug-in
    Thanks for the post. My concern is removing existing bracket from the left side of the inverter.
    How hard and extensive is it? What's the tool required? Just doesn't like that fact that I have to remove something so close to the inverter, but then I get scared easy as far as touching these components.
  7. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I believe you have to remove only 2 screws and it should take less than 3 minutes. ;)
    It comes with adapter bracket for EASY installation.
  8. torparts
    torparts Senior Member
    417
    641
    Compton
    Part numbers please
  9. Mike500
    Mike500 Senior Member
    2,593
    763
    Not available in the US.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    These engine covers are standard on the Lexus CT200h. Just go to ur local Lexus dealer.
    VS980 4G ?
    KLD_Prius_PI_Synergy likes this.
  11. Seanzky
    Seanzky Member
    150
    28
    NY
    I just installed my engine covers tonight and I was wondering what the metal bracket and extra push clip was for? I can't seem to figure out what they're used for.
  12. Burna J
    1,063
    3,331
    53
    Long Beach, CA.
    What metal bracket? It's been some time since I installed mine. You got a pic?
  13. Seanzky
    Seanzky Member
    150
    28
    NY
    I don't have a pic, but it's about 3/4" wide and 5" long and has two holes on each end. It has a 30-45 degree angle to it, too.
    I used two push clips for the radiator reserve container and then there were two more left. One I used for the inverter cover but I don't know what the extra one is for nor do I have any idea what the metal bracket is for. I'm just paranoid over here, maybe I missed something? :confused:
  14. tanasit
    tanasit Member
    399
    60
    Philadelphia
    The bracket is used for more secure of the cover. It goes on the left side of the inverter case and the hole on it will line up with the hole on the cover so that the fit with the push pin.
    #34 tanasit, May 31, 2014
  15. Seanzky
    Seanzky Member
    150
    28
    NY
    I don't see the metal bracket I was talking about in your pics.
  16. tanasit
    tanasit Member
    399
    60
    Philadelphia
    #36 tanasit, Jun 3, 2014
  17. Seanzky
    Seanzky Member
    150
    28
    NY
    No, that's not it. The one I'm talking about is just a plain metal one. I really need to find mine and take a picture. I'm beginning to think maybe it has no purpose --just packaged in my order by accident.
  18. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Did you get the plastic bracket above?
  19. Seanzky
    Seanzky Member
    150
    28
    NY
    Yup. Everything is already installed. The left over metal bracket and an extra push pin are all I have left and i don't know if they're supposed to go anywhere.
  20. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Anyone figure out what PN this is [​IMG]
