defect in Model One audio system
Discussion in 'Prius c Audio and Electronics' started by Dukebar, Oct 3, 2013.
  1. Dukebar
    Dukebar New Member
    Is it not a major defect of the Model One audio system that navigation audio from a smartphone is inaudible unless the audio system is turned on and set to MEDIA? Isn't there something in the Bluetooth specification that can identify the audio stream as "urgent," and therefore enabling the audio to interrupt other input such as radio and CD?
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    every phone is setup differently. on my iphone 5 gps does not stop radio from playing. but when i use siri, it switches to the iphone. when i need gps from my phone, i just make sure to listen to music from the phone and not the radio or anything else
  3. MBRGuru
    MBRGuru Member
    255
    26
    Nothing that wouldn't be a violation of Bluetooth specification. Some phone makers get "creative" and spoof a phone call to do this...which really is a spec violation but, yeah, Bluetooth is...Bluetooth. So, this isn't a defect.
  4. firstrival
    firstrival Member
    102
    Navigation prompts are usually so brief that I don't think the system would be fast enough to switch sources and still play you the direction before it was over. Maybe if BT could always be on and overlay another source. What I do is use my iPhone as a GPS and also stream music from it through BT. It correctly reduces the playback volume to give directions when needed.
  5. Dukebar
    Dukebar New Member
    Thanks for the great responses. Sounds like "spoofing a phone call" might be a great thing to add to Android and/or IOS as a configurable option. :)
