Headlights – PiP base preformance……..
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 34Hupp, Oct 5, 2013.
  1. mrbigh
    3,686
    699
    Long Island, NY
    Upon your recommendation, I ordered a set of the Morimoto's in good faith.
  2. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    I installed a 5000k hid kit in mine. This is definitly related to the sharp cutoff. Above the cutoff is dark. Below is superb.
    You may wanna aim ur lights up a lil or get a quality set of driving lights.
    SCH-I545 ? 4
  3. Rav
    Rav Member
    92
    52
    San Jose, CA
    Jonny I appreciate the feedback but if I have to do all that, then that is not auto level. Our Lexus RX350 has "true" auto level, the Prius Plug in Advanced does not.
  4. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I don't understand what you 'have to do?' He just gave you an example of how to see the auto-level system work.
    What do you consider 'true auto level' to be?
  5. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    They definitely auto level. It's just the adjustment from the factory has them pointing down too low. Easy enough to fix and the difference is worth the effort.
  6. Rav
    Rav Member
    92
    52
    San Jose, CA
    That example is a bit ridiculous, I am not going to do that. If the Advanced had true Auto Level, I should be able to notice the Auto Level continuously like I do in the RX350. Both you and Jonny do not have the Advanced version so maybe that's why you "don't get it". Don't get me wrong, the LED's are very bright but they never auto level and pretty much point downwards. It's the same issue in the city or out in the country, bumps, hills, curves etc. I notice it and so do my passengers. In dark city spots I'm forced to use my high beams otherwise I am going into darkness, it's quite scary and a disappointment for a $40k car.
    How are they "auto level" but "pointing down to low" ? That is not auto level. What is this easy fix that Toyota's Service department is not aware of because trust me I've mentioned it time after time?
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    As I said before what you do not like is the default height setting for the low beams. Many on here have found this to be a problem as well. They easily adjusted the setting so they are set a tad higher and that fixed their problem, as I bet it would for you. This is different from saying it does not have auto level, because it does. There are threads on here with instructions and i think pics showing how to adjut the 'default' height setting.
  8. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I think you'll be very happy w/the 50 watt system. I did use the relay kit w/mine. I'm assuming you ordered that too?
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Toyota decided where they wanted the lights to be aimed. The auto leveling ensures the lights point at that same point no matter what the load, given the load doesn't exceed maximums. Luckily, they included an adjustment so you can make changes. See here: Shaded lights are getting me down | PriusChat
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    My Five has the exact same setup as the PiPA. So I do get it.
    The auto level in the Prii are meant to keep a fat backseat driver from blinding oncoming traffic. The next level up is the continuous dynamic auto leveling. I have seen them in BMWs. I do have concerns of how long they will last with the servo motor constantly working. Two different levels of "auto" leveling.
    An mentioned, the best course of action is to dial up the base "home" level a little. The auto leveling will work from this new "home" location.
  11. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Sorry, it was not ridiculous, and I have owned other cars with auto-leveling lights, so I understand how they are supposed to work. To state it AGAIN, if you don't like the default level, adjust it!
  12. Rav
    Rav Member
    92
    52
    San Jose, CA
    Thanks for the info
    Looks like I need to hire a fat backseat passenger, thanks for the info.
    Maybe to you it wasn't but to me it was. It looks like the adjustment can be made but I hope it's easier done than said. Still too bad that I have to go through this just to be able to see at night. Thumbs down Toyota.
  13. mrbigh
    3,686
    699
    Long Island, NY
    No, I will make my own.
    I have enough spare parts and wires to tackle the job.
    Have you fasten the ballast to any part of the chassis?
  14. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I got my H9 bulbs and installed them tonight. The 'modification' was a 15 second per bulb snip of an extra locating tab then they went right in. Initially it was obvious there was a lot more light, but the fundamental problem remained; the sharp cutoff was causing absolutely no light to get beyond what was safe at about 40mph. I adjusted each beam up slightly and I now have tons of light that I feel perfectly safe with at 60mph on our deer filled back roads.
    I also, for the heck of it, ordered the 9011 HIR bulbs from Candlepower to replace the high beams (which are actually pretty good stock). These are a common direct replacement with similar trim modification for the 9005 bulb, and one I've done before. This will take the lighting from ~5900 total lumens to ~8900 lumens.
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Any one flashed you yet?
  16. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Nope, and I'll keep a careful eye on it. It was a minor adjustment, and if I have any doubts, I'll do the proper adjustment with measurements against the wall. I've done it that way a number of times in the past and never had a car that had such a short reach with the low beams. I visually checked the glare from the front, and you have to be very low to the ground to be below the cut-off and get the glare. These appear to be adjusted very conservatively from the factory.
  17. xliderider
    xliderider Senior Member
    8,119
    3,264
    Honolulu, HI
    Xhenya, can you please post some pics? Thanks. I've done some tab modifications to H8 bulbs before to fit them into the H11 socket to go down in wattage. So it should be easy to modify the H9 bulbs. I use a rotary tool with a grinding head instead of tin snips.
    I wonder which burns hotter in the OEM projectors, 65w H9 halogens, or 50/55w HIDs?
    SCH-I535
  18. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    No pics, sorry. This is a small step up in wattage so it's not considered problematic. Those warnings typically apply when people are talking of stepping up from say 65-100 watts.
  19. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    Thanks for all the great ideas and feedback on my original post for this headlight concern. Last night I adjusted the low beams up (significantly), and what a difference just that made. No one has flashed back yet. Based on "zhenya's" recent post on his H9 bulb modification, I'm going to try that next to see if I can be satisfied with that level of performance. It doesn't sound like anything we do to this projector headlight design is going to get it to the performance of the Gen II HID performance I had before. I think this projector headlight design and "very conservative" low factory adjustment is dangerous, and a rather poor effort by Toyota. I'll post an update after my H11 to H9 conversion.
  20. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    That's because the designers probably had to run their plans through the legal department first. The result of that consultation is what we have here.
