MPG degraded over time
Discussion in 'Gen 3 Prius Fuel Economy' started by prius4owner, Oct 8, 2013.
  1. prius4owner
    prius4owner Member
    84
    30
    Southern California
    Hi All,
    I have 2011 Prius. When it was new it gave me mpg as high as 52.8, but now it is only giving me about 42.5 . Any help will be appreciated. Attached is the picture of the trips. I reset trip B about 9000 miles.
    I perform regular service. Last time when I talked to dealer about this they run some check and told me that everything is fine. But history says that it is not.
    There is no change in my driving pattern nor anything else since I bought this car. Only thing is it is now almost 1 year 8 months old.
    Thanks,
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I'll vote for tires. When's the last time you checked pressure?
    prius4owner likes this.
  3. prius4owner
    prius4owner Member
    84
    30
    Southern California
    Hmm good point. I don't check tire pressure myself, but whenever I give it to service I ask them to do so. But if you see the attached picture, it is trending downwards. It is not that suddenly it started giving me low mileage, but over the time the mileage decreased. I havn't changed the tires since i bought the car as it has enough thread.
  4. fuzzy1
    10,553
    If you care about MPG and tire life, then tire pressure is not something to be delegated to the service folks. They are too infrequent, and too unreliable and erratic. YOU must monitor the pressure yourself. Select a target pressure range that suits your wants and needs, and re-adjust to that target as seasons and outdoor temperatures change.
    The slow trend downwards would be consistent with the natural slow loss of pressure, especially if your car was delivered with the same high factory pressure (for the Pacific boat ride) as mine, and the service people didn't add anything until is fell below the door placard numbers.
    Tire pressure can't explain all the difference you see, but seasonal differences could account for the rest.
  5. prius4owner
    prius4owner Member
    84
    30
    Southern California
    Thanks both of you (fuzzy1 and rdgrimes). I will check the tire pressure and adjust it and see if it gives me better mileage.
    I will update this thread.
  6. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Try it at 40/38 or thereabouts.
  7. bisco
    52,187
    how many miles on her? have you ever had to jump start?
  8. prius4owner
    prius4owner Member
    84
    30
    Southern California
    No I never had to do Jump Start. I have used it almost everyday since I bought it. I have 36000 miles on it.
  9. prius4owner
    prius4owner Member
    84
    30
    Southern California
    After your advise and this chat, I checked the tire pressure. I increased it to 39/37. The last tank gave me 45.2 MPG. This is great.
    Thanks.
  10. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    this reminds me to check mine
  11. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Every time I have my car serviced, they actually deflate my tires to 35 psi (my 17" tires have a max PSI of 45).
    So, definitely do not rely on them to do your tire pressure.
  12. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I tell the service writer what I want have him/her put it on the paper before I sign (same with oil sample request) ...
    Then I actually check before I drive away ... once the young lady came out looked worried and asked what I was doing.. so I said checking the tire rotation and pressure. This is after I once noticed that they did NOT rotate the tire. Funny story !!!
    Empeegee likes this.
  13. mediahound
    903
    155
    Yeah, I'll have to start doing that myself. Also, have them write down 'Do Not Wash' since I don't want anyone else washing (read: scratching) my car.
    It's a good idea to carry a pen and if the service advisor doesn't write it down, you write it down yourself. That way, you have it in writing and can call them on it if they do not comply.
