Will 14 inch steel wheels fit over the brakes of Prius gen III?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by KokomoKid, Oct 9, 2013.
  1. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    The subject says it all. Someone please respond, if you know.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Probably no responses because no one has tried it. Even if 14" wheels would fit, and I'm not sure they would, you would have to try them to be sure to offset was correct. But why would you want them? 15" wheels with the correct offset and bolt pattern are not that expensive.
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    Come on; help this guy out!
    That would be current steel wheels from the wrecking yard made for the current batch of Toyota Corollas.
    The Gen III uses the Corolla wheels bolt pattern.. The Prius"v" wagon uses the same pattern as Camry wheels.
  4. Mendel Leisk
    41,396
    I'd second the above. 15" steel Corolla steel rim (part no: 42611-02471) works fine.
  5. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    The reason I might try 14 inch wheels is that the taller tires might improve ride quality and reduce road noise
  6. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    Also, I think they would look cool with "Bonneville style" smooth wheel covers. If this doesn't work right. Sorry. I'm posting from my phone, not as easy as from a computer.
  7. Mike500
    2,593
    767
    The only way to really find out is to go to a wrecking yard and to get a 5 bolt 14 inch Corolla wheel and try it.
    A lot of wrecking yards have a good return policy.
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    Thinking it might be $ effective to try the michelin energy saver "as" in a 15" version first.
    If it's loud, adding more rubber and weight might not make it any quieter, true, more rubber between the vehicle and the road, possibly more comfort, but as the prii are after superior mileage, they seem to ride a bit rougher (less things jiggling, better mileage) and be a bit louder (less weight) might you be in the wrong car?
  9. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    I just learned that all of this is moot. According to a guy I talked to at Tire Rack, 14 inch wheels won't fit over the brakes anyway, so I'll be using 15's. Thanks for the replies.
