bumper clips
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by austingreen, Jun 3, 2011.
  1. austingreen
    austingreen Senior Member
    13,679
    4,218
    Austin, TX, USA
    When I returned from lunch today, I noticed that my bumper was puffed out near the rear left wheel. I pressed on it and it popped into place. I bought my car in 11/09. Are the clips going bad already that hold it into place? Is there anything that I should do or be concerned about.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Perhaps you hit something like a cat and they popped? Or perhaps cooling and heating might have done that. Probably wouldn't hurt to stop by the dealer and let them know.
  3. austingreen
    13,679
    4,218
    Austin, TX, USA
    I don't think any impact did this. Heating is plausible, its in the high 90s now and we had a cold winter (for us). I was wondering if anyone else is having problems. I'll let the dealer know on the next oil change. I just don't think they will do anything unless I know more, it looks fine right now.
  4. yoshiotu
    yoshiotu New Member
    San Francisco
    Did you ever resolve this? My car has the same symptom. The dealer says that a plastic clip is bent and cannot be fixed. They claim the cause was probably a very small collision that left no dent or scratch, and so it's not covered under warranty.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I replaced the upper clip on mine after I damaged it removing the bumper. Unfortunately it's an integral piece of a part that costs about $40 + maybe 30 minutes labor because (IIRC) the bumper needed to come 1/2 off the car to replace the piece.
    If there is no dent or scratch, then you can claim it was a part failure and possibly get it replaced under warranty by insisting.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If it is still covered under warranty and you are confident that it wasn't hit, don't take that song and dance, talk to the manager of the place and if that doesn't work, call Toyota Customer Care.
  7. cpt09135
    cpt09135 Junior Member
    Irvine
    Mine pops out on the right side. I can pop it back in, but it pops back out after driving. I took off the bumper cover, and the big plastic clip looks fine. Has anyone had luck replacing this clip and having it work even though it looks fine?
  8. kapalacc
    kapalacc Junior Member
    25
    Upstate NY
    The same thing happens to my rear driver's side and front passenger side. Each go back into place when I tap it with the palm of my hand then pop back out after I drive down the road. Really wondering if anyone has been able to fix this on their own- if yes then please let us know how to do it. Thanks!!!
  9. hlunde
    hlunde Member
    419
    75
    My Prius has the same issue after I backed into a shrub. Clip system is simply delicate.
  10. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I had the clip replaced, still have the problem, the part on the bumper itself must be damaged. For some reason I'm glad I found this thread, thought I was the only one with the problem. The body shop suggested glue, I passed.
  11. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I bought my '10 w/43000 miles and the left rear is doing the same. I can push it back in, but the next time I look at it, it's popped out about a 1/16" again. Will be watching for a fix.
  12. 04priusnow
    04priusnow Active Member
    345
    201
    Driver side part # 52576-47020 and passenger side # 52575-47020 these are the rear bumper retainer I ordered the driver side for my car found it on eBay for 40$
    SPH-L900 ?
    mrbigh likes this.
