MPG Display and Actual usage don't match
Discussion in 'Newbie Forum' started by donni, Oct 15, 2013.
  1. donni
    donni Junior Member
    The Prius display shows a better ratio (48.1 mg) vs Actuals (47.2 mpg ) Anybody has similar experience?
  2. Mendel Leisk
    42,251
    Yeah, pretty much everyone. The numbers you quote are actually pretty close. My error (vs displayed) with around 3 years calc'd is 7-8 percent.
  3. fuzzy1
    10,687
  4. bisco
    52,765
    mine is just the opposite, however, in my gen II, it was reverse.
  5. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Same here. Shame Toyota cannot get it right. I use fuelly
  6. donni
    donni Junior Member
    Thanks for all the comments & link to the related thread!!
  7. mikefocke
    4,072
    1,857
    Sanford, NC
    I just drive the car. No hypermileing. The car was bought to be a utilitarian vehicle that gets me to where I need to go with minimum cost and minimum fuss. Do I care about the last 2%? Not when it is getting twice what the SUV is replaced got. I accept that temperature sensors around the home may not perfectly match (though I replaced one that was off by 50% today), no speedometer ever matched the GPS, no GPS matches another GPS, and all mileage claims or displays are suspect. I believe fuelly only to the extent the odometer is accurate. But as long as they are all close enough to give me a relative and approximate value on which I should base my actions....
