Something you wish your Prius had
Discussion in 'Gen 3 Prius Main Forum' started by Delta Flyer II, Aug 23, 2013.
  1. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I think Mike means instead of a 1.3kWh battery, replace it with a 4.4+kWh battery in the regular Prius. You'd have more range in EV as well as more room for brake regeneration but wouldn't require plugging in.
    WE0H likes this.
  2. markabele
    5,084
    1,782
    Nebraska
    I guess I don't get it....why not just get a PiP if that's really important to you?
  3. WE0H
    WE0H Senior Member
    3,247
    528
    PIP doesn't come with the 17's or solar roof and has the chrome stuff on it.
    It would be nice to have the larger battery capacity as an option on the regular Liftback. The car would get higher mpg's as well as running further in EV mode yet not needing to plug in. The software could also be changed to allow EV mode at highway speeds. The electric torque limiting could also be turned down to allow that 300 sumthin foot pounds of torque at higher speeds to give the car a stronger acceleration for those times a person needed to pass or more grunt to pull out at a busy intersection when they have no other choice but to go or sit there and piss off people behind them ;-)
    Mike
    Mobile on my SGH-i717
  4. markabele
    5,084
    1,782
    Nebraska
    So basically you want a PiP with 17's, chrome, and solar?
    You do realize you don't ever have to plug a PiP in right?
    You basically just defined the PiP in that second paragraph.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    No chrome on the front n back ;-) Make it an option as well as that other stuff :) I was thinking of ordering a PiP and did signup in the beginning, but then I discovered the solar roof and Plus Perf Package and ordered a Four instead ;-)
    Mike
  6. bathala
    bathala Member
    128
    30
    Area 52
    Atomic or Satellite controlled clock. Does not require adjustment for DST or crossing time zones.
    NOLA_Akita and haole man like this.
  7. haole man
    haole man Member
    107
    35
    Podunk, California
    Absolutely! We should never have to set an electronic clock.
    NOLA_Akita likes this.
  8. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Only two things I wish I could have on my 2010. An optional as well as reasonably priced plug in conversion and I wish the CVT had a lock up option when on the highway. There nothing is more annoying than watching the RPMs bounce up and down by several hundred on the Scan Gauge at 55-60 mph while on a relativity flat road. I'd bet I could easily pull another three or five highway mpgs just with that one change.
  9. markabele
    5,084
    1,782
    Nebraska
    Totally agree with you about CC. Seems like they could enhance it much better for fuel economy.
    But there already is a reasonably price plug in. It's only a little bit more than a similarly priced regular Prius. Pays for itself eventually for most people.
  10. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Putting in that much battery pack and leaving out the plug would be ridiculous. You basically want a PIP with different options. That's understandable.
    WE0H likes this.
  11. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    This is an especially good idea because the clock on my 2010 runs fast. I had it replaced; the replacement runs fast too.
  12. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Perhaps something about your driving is manifesting relativity effects? ;)
    VTAERO and southjerseycraig like this.
  13. southjerseycraig
    438
    107
    Cherry Hill, NJ
    thanks for the laugh!
  14. Jay Gloab
    Jay Gloab Junior Member
    27
    The larger battery in the PiP comes at the cost of no spare tire, right? Not sure I'd take that trade. Maybe they could find another spot to shoehorn it. What's under the rear seats?
    WE0H likes this.
  15. Tideland Prius
    16,589
    In most cars, that's where the fuel tank is.
  16. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    More ground clearance, I'm tearing up the front of my car trying to get into my driveway. I'm heading for the bodyshop again on Tuesday!
    xpcman likes this.
  17. Tideland Prius
    16,589
    I ripped off the underbody shield just before Thanksgiving/Columbus Day weekend. :cry:. It's fixed now but there are some parts where the low ground clearance works and other parts where it doesn't.
  18. Perkolator
    Perkolator Junior Member
    33
    Sacramento, CA
    wish our new Prius came with extendable sun visors and a real deck lamp on the liftgate for viewing items in back at night (the tiny light on the side is a joke)
  19. WE0H
    WE0H Senior Member
    3,247
    528
    Change it to an LED and it will be much brighter ;)
    Mike
  20. Perkolator
    33
    Sacramento, CA
    I'm considering getting the rear hatch LED upgrade kit from Japan. LED interior lights are definitely going in, but with only one dinky light on the side of the trunk, which gets blocked by stuff in the rear - a proper overhead light is the only fix for me.
    WE0H likes this.
