Thoughts on TRD Rear Sway bar....
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bluemansegundo, Oct 16, 2013.
  1. LOVE IT!
    84.2%
  2. Not that big of a deal
    13.2%
  3. Did not notice any difference.
    2.6%
  1. bluemansegundo
    bluemansegundo Junior Member
    I would hope that a couple of you folks that added the TRD Rear Sway bar could give me a reason that I would like to spend $230 on this upgrade. I already did the TRD lowering springs and LOVE the solid handling. (It made my highway commute easier as well, much better tracking)
    I spend about 65% of my driving on the highway...Will my ride get noisier? Will I notice the bumps more?
  2. xliderider
    xliderider Senior Member
    8,078
    3,235
    Honolulu, HI
    A sway bar controls body lean. It shouldn't make your ride bumpier or noisier.
    SCH-I535
    bluemansegundo and sarir97 like this.
  3. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    That's not entirely true. A swaybar is a torsion bar that controls body lean by effectively increasing the spring rate while cornering. It won't have nearly so much an effect on ride quality as springs or dampers, but it will have some effect.
    DtEW and bluemansegundo like this.
  4. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    Makes cornering truly enjoyable. Get it.
    bluemansegundo likes this.
  5. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
    I can tell you, having the bar installed myself, that the rear of the car feels more planted to the ground when fast cornering or when driving fast on curvy roads, for example, the stretch of the pacific coast highway between San Simeon, CA to Leggett, CA. Not as noticeable in feel as stock springs to TRD springs transition.
    Will it make your Prius feel like a whole different car? Should you go out thinking you have the handling capability of a Porche? No. IMHO, not a worthy investment if you plan to drive the Prius like 90% of the Prius drivers you see on the road.
    Only noise you'll get from the sway bar is if the end-links are not tightened to spec (or installed improperly). Then you'll hear popping noise everytime you run over a bump.
  6. JazzyCT
    JazzyCT Junior Member
    Stamford, CT
    I had mine installed this past weekend. It cost me $250 for the part and $110 for the labor at my local dealership. Two thumbs up!
  7. bluemansegundo
    Good info! Which tire are you running?
  8. Steve Type-4
    174
    102
    SoCal
    I have TRD sports spring installed, like yourself. Currently running on stock tires + stock 15" wheels.
    Did the install myself without lifting up the car in under an hour:
    TRD rear sway bar costed me $212.55 at Toyota Part World, where I also got my PLUS ground effects kit.
  9. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    Tampa, FL
    get it, and install it yourself. Then have fun
  10. toyopri808
    toyopri808 Active Member
    226
    116
    trd springs and sway bar = a must
  11. WE0H
    WE0H Senior Member
    3,247
    528
    I ordered my car in 2012 with the full Plus Perf Package. I drive many rental Prius and can say it is a night & day difference in the handling improvement by having the suspension parts. Worth every penny spent.
    Mike [​IMG]
  12. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I say it's a good upgrade. Even on mild around town driving the back end feels much more solid and less bouncy.
    WE0H and bluemansegundo like this.
  13. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    I would consider doing struts first. If you are running stock tires and struts you are driving a Japanese Buick.
  14. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    My only suspension change is the rear sway bar, added last month, and I've found that it helps the car feel more controlled in crosswinds on the freeway. This was my goal and it met it. I don't feel the need for any other suspension changes.
  15. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I have been very happy with my TRD rear sway bar. And, from the seat of the pants evaluation comparing last year's performance at Road America's Drive for Babies vs. this year's, I think it was worth it. :)
  16. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    I would also consider wheels and tires down the road if you're still on 15's.
    That where it should start actually, where the rubber meats the road. Then everything is built on this.
  17. quickbike
    quickbike Member
    39
    26
    Sacramento, California
    This is the exact reason I just installed mine yesterday. It makes a huge difference, I immediately noticed the solid suspension feeling in the rear.
  18. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Just to reconfirm/reiterate (because I missed where it might have been explictly said), the TRD Prius sway bar has a OD of 22.5mm.
  19. bluemansegundo
    It has not been mentioned.
  20. Steve Type-4
    174
    102
    SoCal
    17"s going in next year, when stock rubbers wear down further. OEM 15" wheels, struts and tires function and ride just fine in all the road trips the Four has been through; rain, snow, desert, forest, coastal, paved, unpaved, you name it.
    Spend $$$$ on suspension upgrades so I can dorifuto the Prius through mad parking apexes while in EV mode at my favorite local grocery store's parking lot or do timed circuit round trip commutes to work and back in LA traffic? Nah, I will pass. My current set up works exceptionally well for what I use the Four primarily for - go on road trips.
    This I noticed. I frequently drive up the 62-hwy to Twentynine Palms, CA and the crosswind along the stretch of the 62 between the 10-fwy leading up to Morongo Valley does wonders to an unlowered and swaybar-less Prius.
