Headlight identification
Discussion in 'Gen 3 Prius Main Forum' started by mactalla, Oct 18, 2013.
  1. mactalla
    mactalla Junior Member
    Could someone tell me what are the five small lights that run horizontally? I have never seen them illuminated and the user manual ignores them.
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Purely decorative. They look like cool LEDs, but sadly they are not.
    SCH-I535
  3. mactalla
    I was afraid of that :(
    Has anyone retrofitted real LEDs into there?
  4. xliderider
    8,140
    3,276
    Honolulu, HI
    Yes, it looked gr8. :D
    SCH-I535
  5. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    SHAME ON TOYOTA!:mad: that is like a trick. they should be ashamed.
  6. fuzzy1
    10,412
    But it was a huge amount of work.
    I believe at least one Prius version actually does have working LEDs there. The PIP?
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    My Five has real Led eyebrows.
    SAMSUNG-SGH-I747 ? 2
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Here a pic of my Prius Plug In Advance. Same LED headlights as the Prius 5.
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    The above was only beginning 2012, 2010/11 didn't have it.
  10. ataylor2
    ataylor2 Member
    122
    East San Francisco Bay Area, CA
    I thought about converting to the LED lights but it was too expensive for me. Also thought about fitting LED's into those spots. In the end I wound up doing simple strips and HID retrofit.
  11. Former Member 68813
    3,524
    983
    US
    Did you place it outside or inside the headlights?
  12. ataylor2
    ataylor2 Member
    122
    Its inside the light. I already had it open to put the HID projectors in, so I blacked it out and added the LED's
    Former Member 68813 likes this.
  13. Steve terry
    Steve terry Member
    217
    Oklahoma
    My prius III has the LED as day time running lights
  14. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    All Prius liftback and PiP beginning with MY 2012 have LED DRLs in the turn signals, not the headlights
  15. fuzzy1
    10,412
    But not in the pictured location, inside the headlight housing. Your LED DRLs are in a separate housing below the turn signal.
  16. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    ataylor has the older model without OEM LED. His Knight Rider LED is a mod.. (y)
  17. Gkui
    Gkui New Member
    Here is my day time running light,
    The 120cm led strip is white color at day time, when light off, 150cm should be better.
    Just place on the top of black rubber,
    Good for white car , i think
    For your ref
