Are mountain descents of 4-5 minutes [getting 99+mpg] bad for the battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 18, 2013.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    While driving the mountains in VERMONT, [ with the foot off the gas], I make many descents of 4-5 minutes at a time, getting 99+ mpg, speeds of 80+ mph.....Is this bad for the Prius battery?
    I have not had any issues driving like this for the past 5 years on my 2008!!!
    *My foot off the gas with the Prius in D, I'm going down the mountain @ 80+ miles per hour, no engine braking!!!
    **If I don't put my foot on the brakes, my Prius does not brake, it keeps gaining momentum and speeding up!!!
    ***My speed could probably keep going to 100+mph, but I'm already at the bottom of the mountain...lol
  2. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I believe the battery is protected, you will notice a change of sound when your battery is fully charged. That means it is no longer getting charged up, and so when you apply the brakes you are really using the brakes not the regen system. So that's where B mode is handy to use engine braking. I expereince this in PA at Rt 40 on the Uniontown hill.
  3. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    It will stop charging the battery and use the engine for compression braking under those circumstances.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I just completed a trip through the NC mountains this past weekend and was monitoring the HV battery parameters with Engine Link on my iPad. When making descents once the battery was fully charged at 80% SOC it would transition to engine braking as stated above, where the engine acts like an air compressor.
    Monitoring battery SOC, temps, etc. I did not see any problems. Actually the battery temps did not rise as much as I was expecting.
    ftl likes this.
  5. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    Is this an area where Gen2 is differert from Gen3?
    I am thinking my car does not go into auto-engine-breaking, must use B mode.
  6. ETC(SS)
    7,226
    Good News: Your battery will be just fine. The folks in Aichi planned on people using their Priuses in places (like Japan) that are topographically diverse.
    Bad News: You were only getting 99+ MPG if you disregard the energy that it took you to get up the hill. Or.....A Hummer H1 will also get 99+MPG going down the same hill. ;)
    Good Luck!
    Enjoy the fall scenery!
  7. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Since I have not had a Gen 2 I cannot answer. For my Gen 3 once the battery SOC hit 80% you could hear the engine rev up as it went in to engine braking mode without me changing to B mode. On the next descent I did change to B mode after the engine had already transitioned to engine braking and could not notice any obvious difference.
    I do remember reading that B mode will limit regen to some degree if your battery is not already at 80%.
    Maybe some others that have had the Gen 2 and now have the Gen 3 can answer your question.
  8. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    It could be, but it would be a curious omission. Engine braking has always been an effective and free way of slowing an ICE vehicle on a descent. The car would have to intentionally decouple the wheels from the ICE in order for this not to happen. A simple test would be to lift off the gas on a descent with the battery full. Does the car slow? If so, you are seeing the effect of engine braking.
  9. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    I think my Gen2 keeps going faster. But I am not the expert. There are many past threads on this I am sure, I am just too lazy to check back.
  10. Snookay
    Snookay Junior Member
    auto braking would SUCK. i hated all of my cars that that used auto braking while i had my cruise control on. Let my car build up all of the speed that he it wants.
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    While I still had room in the battery for regen the cruise control did a great job of maintaing speed. Once the battery was full and started engine braking, then it could no longer maintain set speed and started gaining speed to the point that I would have to use the friction brakes to keep from overspeeding.
  12. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Here you go. ;) It does it just as expected. Automatic B-mode at 84% SOC | PriusChat
    wjtracy likes this.
  13. Bob G IA
    Bob G IA Member
    167
    51
    Actually the best I've seen with my Suburban on a downhill is 45 MPG. I doubt a Hummer would ever do much better than 60 MPG even when coasting down hill. That's the flaw with none hybrid autos, the ICE still consumes fuel, even on downhills and if you turn the ICE off you loose power brakes, power steering & the A/C.
    As far as regen braking goes, Toyota, I believe, made a wise choice in avoiding full charging and full discharging of the traction battery. By stopping charging at 80% they avoid the heating affect that 100% charging causes. I suspect that cellphone & laptop batteries would last much longer if the chargers for those devices were setup more like the Prius. But then they wouldn't be able get you to by a new phone every 2 years, lol.
    Data Daedalus likes this.
  14. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Most cars built in the last 25 years or so consume no fuel when off throttle with the engine spinning. Hybrid or not.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    All the folks above are correct. Just a comment about the engine braking, either because you filled that battery or chose to use B mode.
    The harder you brake, the faster and louder the engine sounds. This is to be expected.
  16. Bob G IA
    Bob G IA Member
    167
    51
    I'm interested in hearing the source of your information. From everything I've seen, read & heard very few gas engines are setup to completely turn the fuel off when the engine is turning.
    Update - I appear to have posted too soon. I did some google searching. looks like more vehicles do full fuel shut off during coasting than I expected.
  17. ski.dive
    964
    244
    I have gotten speeds in excess of 80+mph & 99+mpg with no one in front of me, going down some mountains in Vermont!!!
    NO engine braking.
  18. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I think that getting up to 80 mph, without your foot on the brake pedal, on a steep hill, with a full battery, would be expected since the ability of the design to simulate the behavior of a conventional car only goes so far. I go down long descents here, such that the energy history graph on the MFD shows all bars at 99mpg. It is the engine I worry about more than the batteries. I shift to B mode manually sooner than the car does, since I know the terrain. The regen current is limited when the battery is full, and especially if it is getting hot, so there is not much help there.
    The engine does not provide all that much stopping power, and I don't feel good hearing it revving at 4000rpm frequently. I suspect I will not see the long brake pad life that most others report. I turn the AC up and roll down the windows for increased drag. A nice motorized spoiler would be helpful.
  19. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Come again? If the battery is full, and you don't manually put the car in neutral, it is engine braking.
    fuzzy1 likes this.
  20. ski.dive
    964
    244
    My foot off the gas with the Prius in D, I'm going down the mountain @ 80 miles per hour, no engine braking!!!
    If I don't put my foot on the brakes, my Prius does not brake, it keeps gaining momentum and speeding up!!! ***My speed could probably keep going to 100+mph, but I'm already at the bottom of the mountain...lol
