Michelin Energy Saver AS increased noise after 15K mi.?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by subjective, Oct 18, 2013.
  1. subjective
    subjective Member
    203
    30
    I have been very pleased with these tires but now road noise has increased. I just rotated the tires and the noise is still there. Have others had this same experience with the Michelin Energy Saver AS tire?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I do not have the Energy Savers but I do have the Primacy MXV4's. Mine did the same thing after similar mileage. I had a very noticeable decrease in noise when first installed then noticed a slow increase in noise as the mileage increased.
    I think this will be true for any tire as the tread depth decreases.
  3. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I also noticed an increase in road noise as my Goodyear Fuel Max tires wore down on my volt. After 57,000 miles I replaced them with Primacy MXV4 tires. Perhaps I should gone with Ecopia EP422 tires since I've taken a roughly 8% hit on mileage even after 3,500 miles versus what I got on my old worn down tires.
    How many miles has it been since you put the Primacy MXV4 on your Prius, what tires did you have before, and what kind of mpg difference have you noticed?
  4. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I have about 37k miles on the MXV4's now. I had the Yokohama Avid S33D as the OEM. I originally saw about a 4-5 mpg decrease with the MXV4's but now it is has gradually increased to just about where the mpg was before replacing.
    Jeff N likes this.
  5. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I have 20K on the ESAS and noticed it as well, but no where near the noise of my stock Yoko's when I rotated them. As a matter of fact the ESAS seem a little quieter now than when I first rotated them.
  6. subjective
    subjective Member
    203
    30
    Thank you. I'm glad to know that. I think I will rotate them back. Next time I probably will buy the Bridgestone LRR tires which I can buy more easily at a lower price and better service.
  7. michinnom
    michinnom Member
    162
    29
    you don't have super sonic hearing. its in your head. go see a shrink :D
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    had the same experience with A/S.. rotated tires, ran 1,000mi still noisy.
    Turn out rear hub was the culprit.
  9. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    That's ok, I'm trying to reduce the overall demand for them so they will be available when I wear these out.
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We have about 30,000 miles on our 195x65x15 Michelin Energy Saver AS with all tires
    inflated to 44 PSI. I have not noticed any increase noise...
