1-Year comparison 2007 Prius/2012 PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Cacti, Oct 20, 2013.
  1. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    From my spreadsheet:
    2007 Prius (11/17/2011 through 11/17/2012)
    2012 Plug-in Prius (11/17/2012 through 9/17/2013)
    Average MPG: 53.34
    Average MPG: 87.65
    Miles driven: 15798
    Miles driven: 16066
    Average Fuel Cost Per Gallon: $3.54
    Average Fuel Cost Per Gallon: $3.50
    Cost for fuel: $1,045.57
    Cost for fuel: $642.12
    Gallons used: 296.16
    Gallons used: 183.29
    Cost per mile: .065 cents
    Cost per mile: .040 cents
    HV/EV Ratio: 34% EV 65% HV
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    65% HV miles would mean 10,443 miles on 183.29 gallons. This means 57 MPG for gas miles and you were able to displace 34% of the miles with electricity.
    Three ways of saving gas at play here.
    1) Replacing with electricity
    2) More efficient gas engine
    3) EV miles eliminating inefficient gas miles (short trips - engine warm up)
    3PriusMike, retired4999 and markabele like this.
  3. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Very nice data, but how about cost of the electricity? is that included?
  4. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    I have not had to pay for any electicity, solar panels at home, free ChargePoint stations and I'm able to charge at work without any costs.
    Cacti
    szgabor and wjtracy like this.
  5. inferno
    inferno Senior Member
    1,072
    405
    Is 55 mpg for your 2007 calculative or overhead display? I can't seem to get near there consistently...My average is creeping to 49 mpg with 40k miles.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I was wondering the same thing. Impressive either way for a Gen II.
    I also wonder what the OP could achieve in a regular Gen III. 60mpg or .058cents/mile? That would close the cost per mile difference to approx. .02 cents s0 the break even ($5,000ish) would be in the 250,000 mile range. He needs to get that EV ratio up.
  7. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    The 2007 mpg was from actual tank fills. Just now having divided the miles/gallons I believe I made an error, the correct mpg should have been 53.34. The 2012 PIP mpg was also not correct based on dividing the miles/gallons and should have been 87.65. Will have to check my spreadsheet to determine the discrepancy.
    Cacti
  8. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    I have a round trip 258 mile highway commute to work, this is what kills my EV/HV ratio. I commute once a week, not daily.
  9. fotomoto
    5,639
    3,815
    So. Texas
    Ahh, well that certainly makes it difficult. What about the rest of the week? Can you only plug in at home?
  10. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    While at home I can charge at the local ChargePoint stations. I usually drive approximately 100 miles while I'm home doing short trips, these are all EV only miles.
    Cacti
  11. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    GEN II (I had one for 2 years) was accurate on the display. It was not biased at all like the Gen III. My calculated and FSD for individual tanks was within 2% +- not like the current Gen III. And overall mpg was even closer to calculated.
    Toyota screwed this up (most likely on purpose). I must add I was not doing 55mpg for yearly average mine was 49 over the almost full 2 years I had the Gen II (which I got new).
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Economics aside, these 100 miles per week short local trips all EV only miles are the big advantage of the PIP over the regular.
    The 258 miles highway commute once a week gives PIP advantage over other plug-ins like the Volt.
    PIP is the car for you, even with 65% HV miles.
    usbseawolf2000 and markabele like this.
