So my new system install is 95% complete
Discussion in 'Gen 3 Prius Audio and Electronics' started by drowssap, Sep 17, 2013.
  1. drowssap
    drowssap Member
    154
    30
    I have read through the threads in the audio section for a long time and had a really hard time figuring out what I wanted to do. Many people have "upgraded" their systems but not many have done large custom installs. My big want was to keep the whole thing looking super clean and factory. Well I just stopped by the shop today to take a peek and after a week's worth of work I think it is the best that it could possibly be with the equipment I chose.
    First thing was that I wanted to keep the factory head unit. It isn't the best radio out there but I really like having all of the factory functions. I have a prius 3 with the non-jbl nav. So I had a JL Audio clean sweep installed. For the fronts I used Jl Audio C5 653's. The main woofer and 4" mid are in the door and the tweet is in the factory dash location. I was told that the crossovers were dialed in to provide superb staging. The rear doors hold a pair of JL Audio C3 convertible coaxial 6.5's. For the low end I had a custom carpeted box built with exact matching carpet holding a single JL Audio 10W7. Powering the whole system is a Memphis MC5.1400. Beautiful amp that is a hybrid of analog and digital tech. From what I am told...Analog signal runs front and rear door speakers but the digital side of the amp powers the sub which should help with keeping the power draw down. But with the silk dome teeters and analog signal, there is A LOT of warmth in the sound that I don't have in my tundra with all digital equipment.
    The best part of the job was that the entire interior was stripped down and covered with Hush mat. Even the roof! After taking a look at the car today for a minute, the awesome solid sound that came from the thump I heard when closing the door was the most exciting part of the project! I know this thread is lame with out pics but I should get a few by tomorrow or the latest wednesday. I don't know how many install pics I can get but will definitely work on it.
  2. BillyBuerger
    BillyBuerger Junior Member
    26
    I
    Sounds like a nice build. It'll be great to see the pics.
  3. drowssap
    drowssap Member
    154
    30
    Ok....so the first pic is of the 10W7 in the new box. The internal dimensions are built to spec but the exterior was made this large just because I didn't want a small box flopping around!
    This Next pic is of the Memphis amp that while looks beautiful....it was ripped right back out due to it being a piece of garbage! It has very low headroom and the sound quality was terrible. All sorts of noises were coming from this thing.
    This is my quick disconnect so that I can remove the box on the fly and do it very easily!
    Here are the control knobs for the clean sweep and the bass.
    And here is what replaced the Memphis amp! A JL Audio HD 600/4 for the C5 653 components in the front and the C3's in the rear doors. The other amp is a HD 750/1 for the sub.
    The thing is that now I can finally mess around with tuning. I really want to replace the HU but as of right now, there really aren't any high quality SQ double din decks. There are quite a few that are expensive and have neat features, but none that are THAT much better than what we already have from the factory as long as you have a clean sweep or DSP. Now the other thing is that while I do like the sound of the C5's, they are most likely coming out and being replaced by a set of Focal 165 KRX3's. The gain on the amp is set correctly but the crossovers have a built in overload protection circuit that just cuts off the tweeters when the volume is increased. I listen to a lot of live band stuff and that type of music is just too much for the JL's.
    I don't have any other pictures of the install as of right now due to the fact that I dropped the car off and picked it up completed! The installer does have some install pics and I will try to get them from him and upload them here. Any opinions on the equipment is welcome! Any advice is appreciated!!
    Emcguy likes this.
  4. drowssap
    drowssap Member
    154
    30
    Ok....lots of changes coming in the very near future. The non-jbl navi unit is just plain junk! I am switching it out for the pioneer stage 4 DEX-P99RS. I hate switching to a single din but you cannot achieve this sound quality in any other head unit right now. Not to mention that I really hate the cheap look of just adding that black plastic pocket to fill the space so something custom will be thought of. Obviously the clean sweep will be coming out! Next I will be adding an additional JL Audio 600/4 which will be giving me a total of 9 channels! Reason for this is that I will be running active with out a crossover. I will be swapping out the C5's up front for a Dynaudio Esotar 3 way set up. I will be using the E110 tweeters, E430's mid's and the 650's for mid bass. I will be leaving the C3's in the rear but eliminating the tweeter and just use the mid to fill the space in the rear. I will set up the time alignment with the C3's disconnected so that it doesn't mess up the detection and then just tune those by ear. I may have access to an RTA so that the whole system can be tuned as close to flat as possible. Hopefully this is the set up that works for me!
  5. dan_rc3
    dan_rc3 Junior Member
    This thread is great! I love seeing someone else doing a very high sound quality install, and it looks like you are going top notch on this. It's very fun to see the results of the custom installs, I like everything you have going.
    I am jealous you are going to have the Pioneer deck, as the reviews on that thing are crazy. I have a 2012 Prius V with JBL and have left in the factory head unit due to the rear camera and all the other items in the screen. I am doing an Audison Bit Ten D processor to go with the factory head unit and hope this will work well. In addition, I have Focal 165KR for the front and Focal PS165's for the rear, with a JL 10TW3 sub all powered by a JL Audio HD900/5. My plan is to have the sub installed beneath the rear floor, but with cable long enough to pull the box out when I don't need the storage space. I'm hoping to have this all installed in the next week, and may have some photos to post when it's all done.
    Can I ask you to describe the difference between going active for your speakers? I didn't really explore that world when designing my system...
    Thanks a lot and I appreciate the thread.
    Dan
  6. Jonathan Padilla
    Jonathan Padilla New Member
    How many watts are your running currently?
    I have Jl C2-600 all around and is going to be power by a XD-400/4
    I also have W3V3 Sub at 20hms powering by JL JX 500/1
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Great Work.
    I always marvel at the quality of work some people are able to apply to their Prius...and other vehicles. When I see a thread like this I feel so "mortal". My greatest upgrade so far has been duct taping cardboard partitions into my under the floor trunk organizer and with great difficulty installing a wheelskins steering wheel cover.
    But I enjoy seeing the quality of work and end results people are able to create with their projects. I just know my strengths and weaknesses...and sometimes I have to just sit back and say...Great Work...I could never do it.
  8. drowssap
    drowssap Member
    154
    30
    I will have 1950 watts total. So far I have the new HU and the Dynaudio speakers but I am gathering up a lot of little stuff for the instal. But what you have sounds great....especially if you love the sound it produces for you. What you have blows away what I have in my tundra but what I have in there works just fine for me.
  9. drowssap
    drowssap Member
    154
    30
    Well I also have help so I can't take the credit for all of the work but I also want to point out.....those wheel covers are RIDICULOUS to install !!!!
  10. Grren4ever
    Grren4ever Active Member
    347
    167
    Hi drowssap, love your system! I am thinking of purchasing the JL audio C3-650's to replace the front and rear speakers of my prius. I understand that JL audio also makes the C3-600's which the speaker diameter is slightly smaller. Did you have any problems fitting the 650's into the rear doors? Did you have to modify anything for fittiment?
    Thanks for a reply.
  11. Jonathan Padilla
    you will always have to Young the speakers either way
  12. drowssap
    drowssap Member
    154
    30
    Well first I can tell you that you might want to hold off on buying any speakers due to the fact that I will be selling mine with only about a half hour of use! All packaging and paperwork included. And my speakers are much better than the ones you quoted. I will also include the custom mounting plates for the doors!
    Aside from a custom mounting plate....no real modifications are needed that I can remember but I will know much better when I remove these in just a week or so and will definitely get back to you!
    Here is a pic of them during a mock up:
  13. Grren4ever
    347
    167
    I'm guessing you didn't like their sound if you had them for just 0.5 hours and decided to get new ones...!
  14. drowssap
    drowssap Member
    154
    30
    No I actually liked the sound very much. I wanted to go fully active and you can't do that with these speakers. The crossovers have to be used and does not work with what I am trying to do
  15. drowssap
    drowssap Member
    154
    30
    check out what will fill the new open din slot on my dash once the HU has been replaced with the new single din deck:
  16. Grren4ever
    347
    167
    Hi Drowssap.
    Thanks for the heads-up for the C3-650 crossovers. Regarding your comment, the shop has put sound insulation in the doors only, they didn't go all hardcore like yours and put sound deadening everywhere - it would have costed me a lot more money to do that.
    When I receive another new deck from Crutchfield and have it installed into the Prius, I'll see what I can do about the crossover protection. Volume 4 isn't a very high level to listen to!
    Cheers,
  17. Grren4ever
    347
    167
    I looked up my system for the first time today - I can put the volume way over level 4 without any crossover protection circuit cutting in on the C3-650's. It looks like I'm good to go here..thanks for the heads up :)
