Installed 55w 4300k HID bulbs...finally happy with my Prius headlights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Joe-G, Feb 25, 2013.
  1. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    Yes, I ordered the 32 w but didn't like them so I returned them. The customer service was so good I asked about the 4300 55w and they had them.
    Great price but one of the ballasts went bad.
    I can't recommend them. I am going to have to revise my first post, it seems the quality is not there. At least they have good customer service for returns.
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    wow!@ $32..
  3. Dansta
    Dansta New Member
    Dawit likes this.
  4. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    do you have a link?
  5. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
  6. RamAirDave
    RamAirDave Junior Member
    28
    Yukon, Oklahoma
    The problem is the crappy equipment being used. Ddmtuning is just fine and dirt cheap. Oh and not true about 6k not being as bright as stock halogens Lolz! not even close
  7. Kevin Le
    Kevin Le Junior Member
    24
    Seems pretty cheap, is this the right kit to get??
    Also, if I get 4300K is it possible to leave this running all the time (while driving) with out melting or causing damage to the housing or wires?
  8. longshot
    longshot Junior Member
    83
    4300k is just the color no more power drawn
    SPH-L710 ?
  9. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    That's the one I got. Still working perfectly.
  10. Sfcyclist
    1,621
    376
    SF, CA
    that's a great price! it doesn't note if it's an AC or DC ballast though?
  11. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    It takes DC input, using the factory socket. I think it puts out AC to run the lights.
  12. Sfcyclist
    1,621
    376
    SF, CA
    Was referring to output. At the price point, it's seems like it'a DC output. If it's AC, that's a great price!
  13. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    I don't know what it is. I got zapped by one installing it on my vette and it woke me up, I'll tell you that!
  14. Sfcyclist
    1,621
    376
    SF, CA
    Should say on the ballast. NTL, these systems come a long way. I paid just under $100 for my Xenon Depot AC ballast system. Components look well made but the pins appears to be the weak link. It's worked flawlessly but so did my system 10 year ago!
  15. longshot
    83
    I bought the same kit with 35w bulbs. You put 55w bulbs in the 35w kit?
    SPH-L710 ?
  16. longshot
    83
    SPH-L710 ?
  17. Steve terry
    Steve terry Member
    217
    Oklahoma
    I am glad you did all the leg work. I am going to buy them for my 2013 Prius III. But have not decided if I should get 4300 or 6000 bulbs. Comparing them, it looks like the 6000 is whiter than the 4300. Not much but some. But did not see the option for 35w or 55 w. Just 4300 or other colors.
  18. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    I would highly recommend 4300. They produce the best light to see with. There is a reason all the factory bulbs are 4300k. I have had different k lights and by far 4300 are the best.
  19. Sfcyclist
    1,621
    376
    SF, CA
    4.3k are whiter than 6k. 6k are def blueish.
  20. RamAirDave
    28
    Yukon, Oklahoma
    Guys, these kits are $25 on DDMtuning and they work perfect. 4300 is simulated daylight and 6000 is a slight blue tint.
