Anyyone Install Sony CCD Car Rear View Backup Camera w/ Guide Line
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sushiDot, Oct 8, 2013.
  1. sushiDot
    sushiDot Junior Member
    36
    Hello-
    I have a 2013 Prius 4. I am gonna install this camera, wanted to know if anyone with
    a 2013 model have installed this?
    I purchased it on eBay per other recommendations on the site, but it says its for the 2012...I
    am "assuming" there shouldn't be any issues....anyone have any ideas?
    thanks
    j
  2. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    Does the guide lines curve with the steering wheel?
  3. sushiDot
    36
    Here is a pic of what it looks like...we hooked it up to a camera to verify it looking sharp before we installed.
  4. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    And so back to my question, the the lines curve when you turn the steering wheel?
  5. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    I did looked into to this before.....
    Here is the kit connected to the OBD port.
    Not sure if this you were looking for.....
  6. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    lines dont curve with steering wheel
  7. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    But the above pictures suggest that they do? What's the purpose then to tap into the OBD?
  8. riceroni87
    360
    598
    Oxnard, CA
    Ah maybe that thing that connects to obd port. But the camera itself doesnt
    Galaxy Note 2 ? 4
  9. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    You're need to buy a 12v backup camera with NO LINES, since this IPAS (Intelligent Parking Assist System)
    unit already two dynamic tracks built-in into the IPAS module.
    ""This product works by reading CANBUS data of sensor which provided by the electronic stability program of original vehicle in connection with OBD-u2161 computer port into the unit OBD-II, detecting the rotational rate of steer wheel, car speed and the cars lateral acceleration. By considering the above information, the unit will work out the dynamic track in relation to the static track furnished by the camera , and those will be displayed on the monitor or screen.""
  10. sushiDot
    36
    Ok so the camera i have just has some lines built into the camera feed,
    there is no onboard IPAS that it interfaces with?
  11. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Yup, the one u have just Reference Lines built-in, I have the same one too.
    But u can add the IPAS module ($80-$115) to your aftermarket headunit and change camera again with Non-Reference lines.
  12. sushiDot
    36
    Do you know of an IPAS module that is compatable with my unit and where I can find it? I searched for the Yatour unit above couldnt find it .
    also, is there one that will also beep when you get to close or do you need to install
    a seperate sensor unit for that?
    thanks in advance
    j
  13. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    I would like to know what is needed so that the aftermarket backup camera works with my factory unit.
    iPad ? - now Free
  14. riceroni87
    360
    598
    Oxnard, CA
    I used bcus2 wiring harness and an aftermarket backup camera.
    Galaxy Note 2 ? 4
  15. djasonw
    961
    123
    Coconut Creek, FL
    Darn, I wish I was handy. I'm just footy.
    iPhone ? - now Free
  16. riceroni87
    360
    598
    Oxnard, CA
    these are what i used. I have a gen3 prius II with non nav. works like a charm
  17. vandoc
    vandoc Junior Member
    Do you get any white pixelation with light colored backgrounds with your setup? I have the Sony camera and Beatsonic adapter, and I sometimes get a little white pixelation with bright backgrounds
  18. riceroni87
    360
    598
    Oxnard, CA
    It flickers sometimes at low light. But not white pixelations with light colors in background. Ill keep an eye out for that next time.
    Galaxy Note 2 ? 4
  19. riceroni87
    360
    598
    Oxnard, CA
    I had problems with the camera starting up because I wired the camera to the reverse lights. But solved it by running the power wire to the bcus2
    Galaxy Note 2 ? 4
  20. Frankie Alvidres
    Frankie Alvidres Junior Member
    SOCAL
    I have a beatsonic BCUS3 for sale. I changed my mind and cannot return the product where I purchased it. I am going to change my headunit and don't need the beatsonic harness anymore. Message me if interested, I will ship. Very easy to install.
