Tilt! My new 06 is tilted to the left
Discussion in 'Gen 2 Prius Main Forum' started by pocketpenguin, Feb 21, 2006.
  1. pocketpenguin
    pocketpenguin New Member
    27
    Mid-Missouri, USA
    I've been driving my OLD car until I sell it and each night I pull up to the garage and see my beautiful '06 Prius sitting in the garage. Each night I thought, is that thing tilted? Couldn't be. At first I thought I was nuts.
    Well after seeing a tilt for 4 nights in a row, I decide to check it with a level. I put the level on the bumper and... Yup a slight tilt downward on the driver's side. Oh duh, must be the garage floor! But no, the floor reads as dead flat.
    Hmm, so then I FINALLY drive my Prius to work today giving some co-workers a ride to lunch. One of them asks, "Is that thing tilted?" We parked in two separate parking lots, and it looked uneven in each lot. About 1.5 inches from one side to the other (I have not acutally measured).
    I am not crazy. My car is tilted downward on the driver's side. No, I don't weigh 600 pounds and no, there is nothing heavy inside, and yes the tires are all equally inflated.
    Anyone else have a tilted car? I presume that this is not normal.
  2. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    Take it to the dealer. Did it tilt like that when you first got it?
  3. idaten
    idaten New Member
    40
    Pleasanton, CA
    I don't know if Prius does this, but some cars are shipped with 'blocks' in the suspension to keep them from rocking around on the boat. You might want to take a look. But definitely take it back to the dealer.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    congrats.. every prius does this.. just slightly too.. hehe.. it's true.. this question was brought up in 04.. hehe.. so yeah.. it's norm for a tiny tilt.
  5. ceric
    ceric New Member
    1,114
    Fremont, CA
    Man, this is supposed to be a secret. Now that you have discovered it. Will your love toward the Prius be the same?....
    Yes, every Prius is tilted to the left (driver side). According to my measurement (about 1 inch +/-). My guess (pure guessing here) is the left side supports more weight of the HSD. In all other vehicles I have owned, none had this unbalance. I don't think it affects driving dynamics, though. :)
  6. badaka
    badaka New Member
    47
    Boston, MA
    I read somewhere that Prius's sold in the Southern hemisphere tilt to the right. Water going down drains is opposite there.... It's a designed in feature to help it utilize the spin of the earth to aid in coasting. Ever notice your mileage increasing as a low pressure front approaches?
  7. pocketpenguin
    27
    Mid-Missouri, USA
    I didn't notice the tilt when I picked up the car. I'm very meticulous when I get a new car, making sure to check out everything. But the Prius was parked on an uneven part of the lot in the main display area.
    I just did a crawl-under and didn't see any support blocks in the suspension or anything else out of the ordinary. The car tracks OK so nothing wrong there.
    OK, if others say their car is tilted, I feel better. Though, I've never had a car that didn't sit straight. That's something I didn't expect from Toyota.
    I took measurments on each wheel well and the tilt is 3/4 inch in the back and 1 inch in the front. Both tilted down on the driver's side. Must be something in the engine compartment like the motors and "transmission".
    My friend gets his Prius in a week. I'll ask him to take a measurement on his.
    Thanks all.
  8. stevehj
    stevehj New Member
    28
    No matter if others think this may be normal, to be safe take it to your dealer. Better safe than tilted!
  9. Begreen
    Begreen Member
    670
    Western WA state
    Must be in a blue state. Most Priui are biased to the left.
    (put up the flameshields Scotty) :D
  10. Tideland Prius
    16,615
    It'll be tilted on a totally flat surface. It's to account for the crown on the road (i.e. the road is curved so that water can run off to the drains right?). That way, your car will be flat and the car will be "flat" when on the roads.
  11. Kozmik
    Kozmik New Member
    Uh-oh, he's discovered the Prius tilt secret. Shhh. Don't tell anyone.
    Don't forget that the tides also effect the tilt. Hightide is to the left, low tide is to the right, so long as the car is pointed North, the moon is full, and Uranus is ascendant.
  12. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    well, if ya wanted a car dat leaned to da right, ya should have bought a caddy!
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Aren't you being redundant? :p
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Hmm, I thought it was the *drivers* that tilted to the left...
    _H*
  15. naterprius
    naterprius Senior Member
    1,843
    Yes, I agree, there is likely a spring block in the right front strut. Check the ride height with a tape measure. If the ride height is off, and there are no spring blocks, have the dealer install new springs (both sides) and make them give you a four wheel alignment.
    Nate
  16. KTPhil
    KTPhil Active Member
    1,379
    22
    If so, do Brit Priuses lean to the right, since they drive on the left?
  17. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Or if you wiegh more than 300lbs and your the driver ...............................
    No really they do lean a little..
