Wire tapping the rear speakers for a Sub, 2013 Prius Three
Discussion in 'Gen 3 Prius Audio and Electronics' started by oldtone, Oct 19, 2013.
  1. oldtone
    oldtone Junior Member
    Memphis
    Has anyone tapped in to their rear speakers for a sub in a 2013? I read the very helpful thread "Subwoofer install for dummies" but the wire colors are different to the plug, yet still red/white at the speaker. The wires at the top of the plug are green/yellow on my 2013, not red white like the thread above mentions.
    Has anyone been into their 2013 Prius wiring yet? If I tap into the top two wires in the plug will that get me the speaker wires?
  2. 102mm
    102mm Junior Member
    30
    Not sure what system you have but if this will help I tapped the wires coming off of my amp. The front door speakers act as the subs on the JBL system. It was easiest for me to do it this way. [​IMG]
    SM-N900V ?
  3. Vendo
    Vendo Junior Member
    If i change the JBL Audio System is it possible? The Steering Wheel Control is it still working? Because I unplug the JBL Audio system behind connector. The Steering Wheel Control is not work, including Vol + / -, Temp, DISP and Trip.
    How can I do?
  4. Skunkworks
    Skunkworks Member
    101
    You need this
    Or the 4 channel version for a 4 channel amp.
    I would suggest tapping off of the rear speakers.
  5. Skunkworks
    Skunkworks Member
    101
  6. Vendo
    Vendo Junior Member
    I checked Prius 2012 and 2010. They are different on the cable.
    2010 is using 20pin.
    2012 is using 28pin.
    In JBL Amp, 2010 is 3 connector. 2012 only 2.
