Tips on how to clean the rear windshield (inside)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Grren4ever, Nov 8, 2013.
  1. Grren4ever
    Grren4ever Active Member
    347
    167
    So I'm wondering if anybody uses any special glass cleaning products to clean the rear windshield. The Prius manual says to use a dampened cloth and wipe horizontally so not to damage the defogger lines.
    Well from past experience, a water dampened cloth doesn't clean very well; especially when you have dust and grime buildup on the glass. Do you think windex or any window cleaner I get from walmart will be ok for the glass?
  2. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Any window cleaner with soft cloth will do. No risk of damaging defogger paths.
  3. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Don't worry as long as you aren't using something hard like a razor blade;) . I like Invisible Glass by Stoners. You can find it in the automotive section of your favorite store, including Walmart.
  4. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Another vote for Stoner. I feel that the aerosol can works better than the plastic pump.
  5. Ray-o-Vac
    Ray-o-Vac Junior Member
    I
    Invisible Glass or Castle Glass Cleaner.
  6. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    i've also been using Invisible Glass. Apply in the shade and go back with a clean dry cloth tower to get rid of all residue. Worked well for me.
  7. sfvisalaw
    sfvisalaw New Member
    I used windex and newspaper to wipe it clean. Never had any issues the defogger lines.
  8. Mendel Leisk
    41,714
    I've used an aerosol spray automotive glass cleaner. I apply to one of those wands used for cleaning inside of front windshield. As you say, try to stroke parallel to the wires. Then buff with a flannel cloth (diaper).
  9. Grren4ever
    347
    167
    Thanks for the tips...you guys are the best!
  10. inseek
    inseek Enthusiast
    142
    46
    NY
