Triangular Warning problem- Please help me
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eng.Mohammad Eliwat, Nov 8, 2013.
  1. Eng.Mohammad Eliwat
    Eng.Mohammad Eliwat Junior Member
    Hi everybody ,
    Last week i get a strange problem !!
    Master Warning sign ( Triangular with exclamation mark ! ) and a word " problem " in the screen . Thats sign is stay for only 4-5 second !!!
    i get this problem more than four times in different days !! but the last one there were a high temperature sign .
    yesterday i was at maintenance garage and he checked my car but he told me there were no problem in my car and my car is working well !!
    Please anybody can help me !! since am very frightened of this problem !!
    am ready to get you any needed information !
    Thanks alot
  2. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Did you open the door while the car was running? H
  3. Eng.Mohammad Eliwat
    No i didn't
  4. Eng.Mohammad Eliwat
    I Attached a pic of the sign that appears to me !
    i checked the manual but i don't know if the sign that appears in the screen is for the temp. or for the hypride !!!
    Please any farther information from an expert or any prius user !
  5. HaroldW
    716
    95
    Check your 12V battery out-put in the morning with a multi meter on 12v. You want to see 12.6 but not lower than 12V. It may be time for a new 12v battery? H
  6. Eng.Mohammad Eliwat
    Ok , I will try that. but i don't have multimeter :(
    This problem was happened while i was driving . not in a static motion !
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    You may want to check the coolant level in both the overflow bottle and the radiator. If the temp indicator light is on, chances are the ICE is overheating. That is not a good thing on these aluminum engines.
    You can buy a digital multimeter at Radio Shack, WalMart, and many other places. They are not real expensive unless you buy a top of the line one.
    You can also check the voltage with the Prius. Run the test that is in the following link and post back all three voltages you see in the test. Run the test after the Prius has set overnight or for at least eight hours.
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
  8. Patrick Wong
    18,210
    6,511
    Also, check the engine oil level on the dipstick.
  9. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    First of all how many miles? If it's a cooling problem you need to check the coolant level in the radiator when it's cool. Have to remove the radiator support opening cover over the radiator to get to the radiator cap (Picture attached). Only remove radiator cap when engine is cool. Engine coolant reservoir (in front).
    Second Check the inverter coolant reservoir (IMG_1710 near the back) with the cap off and the ignition on. There should be good flow in the reservoir. If not, the inverter water pump may be bad. There is a T-SB recall on that (free replacement).
    If coolant in either reservoir is low, are low add Toyota Super Long-Life Coolant.
    Also check to make sure the v-belt hasn't broken.
    Check to see if there is any buildup of "pink crust" on the water pump, indicating leaking. (picture attached). If so, the coolant level in your radiator is probably low too and engine water pump needs to be replaced.
  10. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    Harbor Freight sells some very inexpensive multimeters (like under $10).
