1. e.e. comings and goings
    e.e. comings and goings Junior Member
    The last week, I began to get a message that oil maintenance needed to be performed soon (although I had driven the car only about 4400 miles since buying it; I thought the dealer had changed the oil before offering it for sale, and I can’t see the car as having had 5600 miles of test-driving on it), so I took the car to a local Midas shop for which I had a coupon to get the oil changed for $21.99.
    The man taking care of it told me that the Prius needs 0W-30, a synthetic oil, and would cost $69.99! Yikes. There went all my savings on gasoline the last three months.
    Is this a typical charge? Even if the oil is synthetic, I don’t understand why the labor alone would cost $23.04 (toward the $69.99). Do extra precautions have to be taken for synthetic oil?
    JMD likes this.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I assume you purchased a used Prius. The maintenance required light turns on every 4500 miles. If you have the owners manual, you will see it's just a tire rotation and inspection maintenance. The actual oil change is required every 10k miles. 2010+ Prius uses 0w20 oil and it implies synthetic so it will be an expensive oil change.
    There's nothing special about synthetic oil in regards to labor. Typical labor charges for mechanics is $60-$100 an hour. $23 sounds about right for a 15 minute job.
    PS The owner's manual say you can safely use 5w20 but you will have to change it out at 5000 mile intervals.
    Turn off signatures in Tapatalk Tapatalk
  3. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    On the Gen 3, Change interval is 10k miles with 0W-20 synthetic.
    Synthetic does cost a bit more, and the procedure of utilizing the 'door' in the lower undercarriage cover does add a bit of time.
    Actual labor shouldn't be >10-15 minutes.
    If you don't wish to do it yourself, you might readily find coupons from your local Toyota dealer, either in your local newspaper or their website that will save some $$.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The Toyota dealer will charge you about $70 for a synthetic oil change. Frankly, a Midas shop is the last place you should be getting service done on a Prius. If you don't like the dealer, there might be an independent shop in your area specializing in hybrid cars. But its certainly not unusual to see charges for synthetic oil changes running about 2x what normal oil costs. That's always been true.
  5. frodoz737
    frodoz737 Top Wrench
    4,722
    2,517
    33
    There is no difference having a Midas shop change the oil than a Toyota Dealership. The key is to at least know they are using the right oil and filter. If you can not or will not do it yourself, then find someone you trust. Don't just go to who ever has the best coupon.
  6. e.e. comings and goings
    I don’t have anything against the dealer, I just couldn’t get an appointment to have the oil changed before Monday, and I was hoping to go off hiking tomorrow.
    I was taken aback at the cost, but if it’s fair, then that’s the way it is. I haven’t investigated how difficult it might be to do it myself. With my ’99 Corolla, I couldn’t even see the filter, so I always took the car somewhere. I used to change the oil in my ’86 Corolla, though.
  7. Paul R. Haller
    285
    43
    Walnut Creek
    I just went through this in the SF bay area. I wanted to change the oil myself and even went so far as to buy in advance the special tool to remove the oil canister from Amazon, 5 filters, and 5 washers from Ebay. Nobody locally even carried the 0-20 full synthetic oil. I went to 4 places. Pep boys had one quart of Mobil one for 10.99. I finally went home and started calling around. I finally located a parts store that had 0-20 Mobile one for 7.99 per. I called the local Toyota dealer and their price for oil was 12.99 a quart and filters were $9.45. To do the oil change for me (are you holding on...) 79.99. I called a local garage who said they would do it for 55.00. I had the ramps, filter, washers, rags, wrenches, a dump container, and the motivation just no oil. I finally bought the 5 quarts and had to drive 20 miles. The oil change was easy, getting the oil, pretty hard. The parts guy said that starting 2014 Ford is now making cars that take the 0-20 synthetic and that should make finding the oil easier.
    -Paul R. Haller-
  8. Mendel Leisk
    41,911
    Was that their price for Toyota 0W20? Up here it's under $6 Canadian per liter. The washer's about $1 and the filter $8 something. And all items readily available, I see no need to buy more than what's required for a single change.
    Regarding the oil change interval, it's 10000 miles or 12 months in the 'States, but 8000 kilometers (roughly 5000 miles) or 6 months across the border in Canada. All I'm saying: the intervals are very variable, depends on your location, and there's likely some showmanship involved.
  9. tach18k
    tach18k Member
    406
    SoCal Beach Area
    10k miles for an oil; change, go to the dealer buy the oil, washer and filter, have any place that knows their stuff change it, most run about $25 for labor only, you wont kill the car by going over 5k miles on oil change, I did mine after 12k, and it showed it.
  10. vskid3
    vskid3 Active Member
    773
    228
    Did you check Walmart? I've seen Mobil1 0w-20 at every one I've checked. Its usually about $27 for a 5 quart jug.
    Tbkilb01 likes this.
  11. Paul R. Haller
    285
    43
    Walnut Creek
    I will not buy at Wallmart. The cost to the community are just too high.
    -Paul R. Haller-
  12. frodoz737
    4,722
    2,517
    33
    This thread is about car maintenance. The proper place for that is Fred's House of Pancakes | PriusChat
  13. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    You won't buy from Walmart citing community concerns, but you buy from Amazon who've put more small community/mom & pop book stores out of business than any other business has!
    Hypocrite!
    Tbkilb01, breaks911 and elementnomore like this.
  14. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I bought the 0w20 the couple a days ago from toyota dealer for a lil over $7 per quart. i put all 4 quarts when i change after 10k miles, you talked about buying 5 quarts did i put less than needed? the dip stick wasnt really any good help to check oil level since oil climbs way too high on sides whenever i check. please lemme know if i need to put more than 4, i put the used oil back in 4 quarts and that pretty much filled the 4 bottles showing very little to no oil burning inside. the filter with oring from dealer was $4.xx but i couldnt change filter since the tool i bought from walmart was 65mm a lil bigger and the adjustable three prong tool from harber freight didnt get good grip and keep slipping, any suggestions or possibly links to cheap 64mm? tool for this service?
    also i did not put washer for the pan, there wasnt any when i changed last time after buying car and i didnt put any this time either. i have put around 13000 miles on it so far with no leaks from screw.
  15. Mendel Leisk
    41,911
    ^ If I put in 4 liters in an oil and filter change, I end up with a level about 2/3 the way up, between low and high marks. I usual cave, and pour in about 1 more cup. Then when I check it a day or two later, it's hovering at or just below the top mark. Seems like it settles down a bit. I am checking the level after letting it run a minute or two. Then letting it sit a bit before the check.
    So putting in 4 quarts, your level might be a bit low for comfort, say mid-way between the two marks. I'd add a couple of cups.
    It's not impossible to check level via the dipstick, just difficult. I know what you mean re smearing oil up the edges of the dipstick. But, if you look carefully, and check both sides, you can usual discern a "stopping point", a bare zone, which is the true level. Repeat a few times and it becomes clearer.
  16. ny_rob
    1,968
    813
    L.I.- NY
    Gen III Prius oil capacity is 4.4 US quarts.
  17. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    I just (this afternoon) bought from Toyota of Berkeley 5 quarts of 0w-20, one filter and one crush washer for a Prius for $48.73, tax included. I'm pretty sure this can be had for cheaper at Hanlees Hilltop Toyota (Richmond), where they are generally a little cheaper for everything.
  18. mmmodem
    2,732
    1,703
    Bay Area, CA
    Yikes, Hanlees Hilltop Toyota just quoted me $69.99 to do an oil change and rotate the tires. I think you've just convinced me to go ahead and let them do it. I can't seem to find any better dealer coupons.
  19. orenji
    orenji Senior Member
    5,887
    3,488
    Its just cheaper and better to have the dealer change the oil. $75.00 dollars is nothing compared to $300 plus to have oil changed at a Mercedes dealer, for my other car. No Joking!
  20. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I think the dealer will check all fluid levels and replenish
